Rear A-spec
Old 04-20-2014 | 10:55 PM
Jriddle8's Avatar
Rear A-spec
I recently installed my whole lip kit this weekend everything came out fine except the rear. Im not sure if there is the lip is supposed to draw below the bumper. I have seen pictures were its low like mine and some where its flush. Did i install it wrong? the holes werent clearly marked like the front bumper ones, these ones had a dot with a line crossing it so i assumed that was it. Maybe i fucked it up? if so how would i go about fixing this
I will post a pic shortly
Old 04-20-2014 | 11:24 PM
paperboy42190's Avatar
i'll take a pic of mine in a bit
Old 04-21-2014 | 12:23 AM
Jriddle8's Avatar
As you can see the gap between the top and the lip.
Ill measure how much it drags by tmr morning.
Old 04-21-2014 | 02:02 AM
i forgot to take a pic of mine when i was at my car earlier. but I do not have that gap. I made sure mine sit flush when installing. It says on the service manual to make it sit flush
Old 04-21-2014 | 02:07 AM
chackhou's Avatar
Mine has a gap as well, but for the price i paid for paint and installation I'm not gonna complain. I've seen other TL Base/Type S A-spec kits with no gaps, slight gaps, and 2cm gaps. It supposed to be flush though, with zero gaps.
Old 04-21-2014 | 02:15 AM
about 80-90% of the rear lips I've seen has a gap. its not really that big of a deal though. still looks good either way, and its not like its gonna rub anything from being couple mm lower.
for ppl with ocd though, having it flush is very important
Old 04-21-2014 | 07:37 AM
alexb92's Avatar
I installed mine myself, following all the directions. My lip sits perfectly flush on the lip in the rear, but on the sides I have a small gap like this. All the mounting screw holes lined up perfectly in the fender well too, as they were predrilled because I had factory installed splash guards. Not sure how else I could have made the lip sit flush without making modifications that the installation guide didn't require.
Old 04-21-2014 | 09:02 AM
1black_seven's Avatar
Slot Machine Lubricator
mine was near flush, and then it kinda started sagging. I'm guessing its normal.
Old 04-21-2014 | 08:09 PM
TWiSDiT's Avatar
Chapter Leader (Mid-Atlantic Region)
Mine sits flush :
Old 04-21-2014 | 11:38 PM
Jriddle8's Avatar
Ugh... guess i gotta take the lip off and redrill the hole and add new 3m tape. What a pain
Old 04-22-2014 | 06:58 AM
dc2kid's Avatar
if its supposed to sit flush i gotta redo mine to it looks like what you have. i cant really remember but when i installed mine i think it wouldn't stay flush
Old 04-22-2014 | 07:14 AM
dc2kid's Avatar
check this thread https://acurazine.com/forums/3g-tl-2004-2008-93/spec-rear-underspoiler-alignment-852321/
Old 04-22-2014 | 01:38 PM
tones160's Avatar
[x] FWCC [x]
lol so i guess if my oem rear bumper looks like that then is bad? However im unsure if it's from assholes hitting my car when they're parking behind me.
Old 04-23-2014 | 08:19 AM
splew's Avatar
Mine sits flush, but like others have said, while the lip is technically supposed to sit flush, not all of them actually do. I think how close you get when you drill the rear holes has something to do with this. Also keep in mind though, the bumper and the lip are both flexy plastic parts, so there's always going to be some variances no matter how well you do the install.
rockvilleTL
09-19-2015 04:44 PM
Dunnik
09-15-2015 11:52 PM
Quick Reply: Rear A-spec
