Question Using a BlueTooth Phone
So, I was calling a few numbers using the BlueTooth feature in my TL...some telephone numbers require you to enter some information from the phone's keypad...is there a way that i can enter it through the navi screen? like for example, i called up tmobile customer care through the car and it was asking me to put the last four digits of my Social Security number and i couldn't do it through the car...i had to go back to my phone to do that...i tried switching the navi screen to AUDIO but that doesn't work...it only gives a picture of the buttons on the steering wheel...is there a way that i can ACCESS A KEYPAD through the navi so i don't have to use my phone?
I think you can hit the "talk" button on the steering wheel, and just say the numbers that you want it to send, and then follow the prompts.
Mike
Mike
i am not sure if that will work...becuase usually it's done through the "clicks" of each button...each button on the phone has a distint "click/beep" to it...so that's how the receiving end can determine the numbers that you press...but i will give it a try tomorrow and see if that works...thanks..
When it did properly recognize "Send", I heard it send the DTMF tones corresponding to the numbers I had stated.
They need to find a different verb!
Mike
MilanoRedDashR
38
09-28-2019 09:13 AM
ivegotthenav
09-11-2015 07:51 PM
DiamondJoeQuimby
09-10-2015 11:40 AM
