Question for the LED experts...
Old Jun 25, 2004 | 09:20 AM
Aspector Gadget's Avatar
Mmmmmm... Anthracite
Originally posted this in the "Ramblings" bu got no response, I figure you guys with your blue LED mods could help.
I have a mid-90's VW, and the master key has a small 1.5 Volt bulb to be used to find the lock in the dark. The incondesent (spelling?) is not very bright. And I am hoping to switch it out with a super white LED that could be soldered to the wiring, if not a direct replacement.
My questions are:
1) What stores can I go to in order to buy LED's and make sure they fit?
2) If I have to buy online how do I make sure the LED will be the correct size and voltage?
Additional info: engraved on the side of the bulb is, *1.5V 0.09W-A. The bulb is just over 1/2" from tip to base, and has a diameter just over 1/8" (constant diameter over the entire length). The battery is a watch type, thin battery, with 625A engraved on it.
TIA
Old Jun 26, 2004 | 08:01 AM
Tedanddenise's Avatar
LED's normally take approx 20milliamperes to operate - although there are a few variants that take more, some less. Try a Radio Shack and see if they can help - you'll not only need a superbright LED but also a dropping resistor (probably) small enough to fit in the enclosure. It's a project that shouldn't be that hard to do.
Old Jun 26, 2004 | 09:56 AM
PeterUbers's Avatar
btw, that's a pretty cool feature!
pplcrew
Jan 30, 2021 08:59 AM
usual.acura
3G MDX (2014-2020)
14
Sep 19, 2015 05:01 PM
Sep 17, 2015 09:01 PM
Greengecko
Sep 16, 2015 08:19 PM
datadr
Sep 12, 2015 09:12 PM
