Question about ballast bracket.
2021 RDX A SPEC
well..do i need it? it was such a pain to get to going through the resonator and all...do i really need to put it back on? does it serve any sort of purpose? perhaps shield the heat from the ballast onto the wiring below it?
i'm talking about this thing:
here is the ballast pictured WITHOUT the above bracket...will it give off a ton of heat to affect the wiring below it?
*this is from an 07/08 base.
thanks
thanks
I am not saying its for grounding, but eliminating that because its aluminum does not make any sense. aluminum conducts electricity just fine.
That makes some sense, or a heat shield from the wire loom
navtool.com
31
11-16-2015 08:30 PM
navtool.com
09-25-2015 05:15 PM
