Question about 6speed MT
Old Dec 16, 2005 | 05:02 PM
SneakAussie's Avatar
Question Question about 6speed MT
I have owned my 06 MT for a couple of months now. I have about 2K miles on it. I recently have had a strange thing happen to me that I have never had before driving a MT. When stopped at a stop light I put it into first gear with my foot on the clutch, when the light has turned green the clutch slips like crazy and the engine revs like crazy to. Its like the clutch wont catch. This has happened twice. Has anyone else experienced this in their MT?
Old Dec 16, 2005 | 05:44 PM
quattrodude's Avatar
Stupid question, do you think you are possible not quite in gear? I would doubt thats the case, otherwise it would seem like the clutch is sticking, i would have the dealer look at it?
Old Dec 16, 2005 | 05:47 PM
PoochaKannInc's Avatar
Shift_faster
Never experienced that. The only thing that I can think is what the poster above me said. If the shifter is not fully in gear...that could happen. I'm sure you would have recognized it the second time around though...so I dont know...
Old Dec 16, 2005 | 05:58 PM
Question
No it was in first gear, Im sure of that. I dont know if the clutch was slipping because the RPMs were too high. Will the clutch slip when the RPMs are way high and not catch the fly wheel? Maybe some kind of VSA control thing going on maybe????????
Old Dec 16, 2005 | 06:03 PM
I have flogged my 6sp pretty hard...you would most def. know if it catches!!!
So I would have to say your clutch is not engaging? Do you smell anything burning??
How do you then get it to go...press in on the clutch and re-release it and then it works??? if so it's sticking...see dealer?
Old Dec 16, 2005 | 06:13 PM
Oh yes , I most definitly smell the clutch burning after this happens. What do you think?
Old Dec 16, 2005 | 06:37 PM
Like the other poster... you can not get too high of RPM for the clutch not to catch... Once I dropped it at a high RPM and got wheel hop like crazy..
Another question... did you let your foot off the clutch? You might have been pressing down on it enough for it to slip... if not.. then you got a problem..
Old Dec 16, 2005 | 06:38 PM
ttliang's Avatar
tTLiang
i was gonna ask u some Qs they asked. but one word for you.... "dealer". warn u they will insult you first for not knowing how to drive a stick. that this first thing they asked me (very politely tho) after my wife burnt my clutch. lol. you have bring your certificates from racing school and mentioned all your high power stick cars from before to shut them up. lol again.
Old Dec 16, 2005 | 10:04 PM
SouthernBoy's Avatar
Registered Member
If what you describe is accurate and factual (not doubting you), you most definitely have a problem and a serious one at that. Get that car in asap to have this checked out. I can assure you that this is NOT normal in any way.
Under no circumstances should this occur if everything is working as designed unless you're the one doing something wrong and from your description, I don't see where you might be screwing things up. However, you do lack some knowledge of a couple of the systems in your car (not a flame.. just an observation). VSA has absolutely nothing to do with the clutch assembly.
The key to your story is the smell. A burning clutch has a very distinct odor. If I had to wager a guess at the problem, I'd say you could be really low on hydraulic clutch fluid, or you could have a clutch master or slave cylinder failing.
Good luck and let us know what you find out.
Old Dec 16, 2005 | 10:39 PM
06 Acura TL's Avatar
REDBULL///AMG
this does sound serious and you should deff see the dealer, i mean with my 6spd even if i redline and drop the clutch it catchs, the only thing i can think of is ur clutch not fully engaging, i mean are yo reving it all the wau with ur foot half way on the pedal? or some sort of liquid leaked on you flywheel(highly doubt that tho) deff see the dealer. good luck
navtool.com
3G MDX (2014-2020)
32
Jan 20, 2016 11:43 AM
navtool.com
31
Nov 16, 2015 08:30 PM
DerrickW
Nov 15, 2015 05:52 PM
STL TL-S
Sep 23, 2015 08:52 PM
