Puddle Light wiring up schematics, and detailed pics.
Old 01-27-2013, 10:41 PM
  #81
TL-S
quanaman's Avatar
I used one in the wheel well. It's available on both pass and driver's side front wheel.
If you open the screws connecting the liner to the side skirts and peel back the liner you should see a grommet with a wire coming out of it about half way up.
I poked a hole and then poked the wire through on both sides; it was pretty easy.
Old 01-30-2013, 11:48 AM
  #82
KB1Spec's Avatar
Sorry to hijack the 3G section but I did my puddle light for my 4G with the correct set up
Old 01-31-2013, 12:39 PM
  #83
dwb993's Avatar
Sweet!
Old 01-31-2013, 01:56 PM
  #84
TL-S
quanaman's Avatar
What kit are you guys buying?
I bought my last set for my old TL from LEDMOD.com and it worked pretty well; but they're back ordered now and only have red in stock
Old 04-21-2013, 09:20 PM
  #85
3rd Gear
Farmerftw's Avatar
Hey guys, I'm new to the forum and i am stumped. I hope this issue falls under this threads subject. I really like the puddle lights and the foot well lighting so i decided to do both at the same time as they require access/tap into the dome supervision wire.
So, i completed the foot well led lighting for all four seating compartments and it looked great. Everything worked fine turning on and off/fading off with the dome light. So, i tapped into the primary foot well wire leading from my original tap in to the dome supervision light to run my negative through the firewall for my puddles. I also installed the switch/diode as provided in the schematic(with lockdots correction). After doing this everything completely died and nothing worked(including the dome light.) I'm assuming i have a short to ground or i have overloaded something. I also used the add-a-fuse option tapping into the existing power seat fuse(20amp) with a 3amp fuse running the lighting i installed. I'm not incredibly familiar with voltage/amp draws and the like. Thought i would give the engineers on here something to puzzle out.
Thanks for your help.
Old 09-15-2014, 09:47 PM
  #86
4th Gear
sanjee4321's Avatar
so the wire splicer hooks up to the main negative and the green wire behind the green 5 pin
Old 10-04-2015, 08:17 PM
  #87
2007 TL
tj19855's Avatar
Thanks!
Old 08-03-2016, 12:42 PM
  #88
Sheila TaĆ na's Avatar
Cant see pics!!!
Hi I want to do this but i dont see any of the pics here😫
cycdaniel
12-17-2019 10:58 AM
oyayjoe
01-01-2019 10:17 PM
Soul_Deamon
4G TL Problems & Fixes
11-02-2015 04:32 PM
oyayjoe
09-12-2015 04:40 PM
Nicho863
09-02-2015 08:12 AM
Quick Reply: Puddle Light wiring up schematics, and detailed pics.
