proper tar and bug removal
new diamond white pearl finally found new black-top. Even with slash guards the sides received a liberal application of road tar. Should I take the car into the dealer for a cleaning, or, is there a safe way to wash off this crap? I've spent about a hundred hours waxing and rewaxing over the past few months with a high quality wax. I thought that would protect me from 'road grimes' but I guessed wrong. A friend suggested useing diesel fuel on a soft rag and gently polishing it away. Then follow it up with a good soap and water hand wash. Is this the norm? Could this harm my paint job?
use stoners tarminator. Here is a link to buy it online. It should be also available at an automotive store
http://www.autopia-carcare.com/stn-91154.html
Use Mineral Spirits .. its safe .. non-flamable and one hell od a lot cheaper than the Tarminators etc which may contain Xylene which isn't very clear coat friendly.
Saturate a rag then gently wipe the area and let the solvent do the work. Don't be rubbing hard as the tar may have sand in it.
Once done wash & rewax.
1 Post
first dryer sheets are not like sand paper and when in soapy water they do not scratch the surface. i've been doing this for years and got the trick from a detailer that washes lamborgini's. I would not trust mineral spirits
I have a turtle Wax bug and tar remover that is in a spray. You spray it on a terry cloth and rub real hrd and it will definitely get the bugs off. I have not seen any effects to the paint job whatsoever. There is also some stuff at a local car wash here in Boston that worked even better, put it was some professional grade stuff.
'06 6MT WDP
Originally Posted by ding069
OMG frankenstein
whateer you do, don't use paint thinner, laquer or anything of the sort becuase it will really dull out the clearcoat.
ExcelerateRep
10-14-2015 08:20 AM
detailersdomain
Wash & Wax
10-09-2015 10:13 PM
