proper tar and bug removal
Old Aug 19, 2006 | 02:04 AM
misokisu's Avatar
new diamond white pearl finally found new black-top. Even with slash guards the sides received a liberal application of road tar. Should I take the car into the dealer for a cleaning, or, is there a safe way to wash off this crap? I've spent about a hundred hours waxing and rewaxing over the past few months with a high quality wax. I thought that would protect me from 'road grimes' but I guessed wrong. A friend suggested useing diesel fuel on a soft rag and gently polishing it away. Then follow it up with a good soap and water hand wash. Is this the norm? Could this harm my paint job?
Old Aug 19, 2006 | 03:06 AM
arshdeep99's Avatar
kerosene is the answer...
Old Aug 19, 2006 | 09:39 AM
csmeance's Avatar
use stoners tarminator. Here is a link to buy it online. It should be also available at an automotive store
http://www.autopia-carcare.com/stn-91154.html
Old Aug 19, 2006 | 06:37 PM
Jesstzn's Avatar
Use Mineral Spirits .. its safe .. non-flamable and one hell od a lot cheaper than the Tarminators etc which may contain Xylene which isn't very clear coat friendly.
Saturate a rag then gently wipe the area and let the solvent do the work. Don't be rubbing hard as the tar may have sand in it.
Once done wash & rewax.
Old Aug 19, 2006 | 08:02 PM
Stackman's Avatar
If you are using high quality wax you should also use a HQ cleaner wax before waxing.
Old Aug 19, 2006 | 09:24 PM
ding069's Avatar
acura-cl.com OG
use dryer sheets (fabric softener) like you would as a wash cloth. wet them and they work great
Old Aug 19, 2006 | 10:56 PM
consultauto's Avatar
Try Wipe Away, less than five dollars at Wallmart, should do the trick.
Old Aug 20, 2006 | 07:51 PM
kobi2002's Avatar
dryer sheets work like a charm. Just soak it in soapy water and wipe away
Old Aug 20, 2006 | 07:59 PM
Jesstzn's Avatar
I sure hope what you all are recomending is safe for the cleat coat .. a lot of things aren't.
Old Aug 20, 2006 | 08:42 PM
kobi2002's Avatar
first dryer sheets are not like sand paper and when in soapy water they do not scratch the surface. i've been doing this for years and got the trick from a detailer that washes lamborgini's. I would not trust mineral spirits
Old Aug 21, 2006 | 08:36 AM
WB56-TL's Avatar
I have a turtle Wax bug and tar remover that is in a spray. You spray it on a terry cloth and rub real hrd and it will definitely get the bugs off. I have not seen any effects to the paint job whatsoever. There is also some stuff at a local car wash here in Boston that worked even better, put it was some professional grade stuff.
Old Aug 21, 2006 | 09:42 AM
Jesstzn's Avatar
Your supposed to let it sit and do the work .. rubbing real hard is going to get you marring in the paint.
Old Aug 21, 2006 | 09:48 AM
MichaelBenz's Avatar
CTS-V Import Slayer
Dryer sheets huh...crazy...I will have to try that one....lol.
BTW>wrong forum. Should be in the car wash forum.....
Old Aug 21, 2006 | 10:07 AM
dero79's Avatar
Dryer sheets, listen to the man! And they are good to wipe down a television screen to remove and deter dust!
Old Aug 21, 2006 | 01:55 PM
SILVERADO's Avatar
i like turtle wax bug and tar remover.
Old Aug 21, 2006 | 03:47 PM
260 HP's Avatar
I use clay bar with good results for things like this.
Old Aug 21, 2006 | 04:43 PM
ward148's Avatar
Use dried Degree deoderant (the kind that always turned the armpits of your shirts yellow). Works great!!!
(jk)
Old Sep 9, 2006 | 03:45 PM
Mike 06 TL's Avatar
'06 6MT WDP
WD-40 works like a charm and is 100% safe.
Old Sep 9, 2006 | 03:52 PM
ding069's Avatar
acura-cl.com OG
OMG frankenstein
Old Sep 9, 2006 | 05:03 PM
Mike 06 TL's Avatar
'06 6MT WDP
Originally Posted by ding069
OMG frankenstein
Care to tell us why you should not use it? WD-40 has a million uses. It actually states on the can that it can be used to remove tar and is paint friendly. It will also take tar off your clothes without damaging them.
Old Sep 9, 2006 | 05:51 PM
mrodriques's Avatar
Of course if all else fails, you can just paint your car black
Old Sep 9, 2006 | 06:16 PM
csmeance's Avatar
whateer you do, don't use paint thinner, laquer or anything of the sort becuase it will really dull out the clearcoat.
Old Sep 9, 2006 | 07:24 PM
HEK's Avatar
HEK
Team Nighthawk Mambo King
Mother's clay..........
Old Sep 9, 2006 | 08:55 PM
ding069's Avatar
acura-cl.com OG
just that the thread was a month and a half old, WD40 works fine tho
ExcelerateRep
Oct 14, 2015 08:20 AM
detailersdomain
Wash & Wax
Oct 9, 2015 10:13 PM
lowgrowl
Sep 26, 2015 05:18 PM
kingbharj
Sep 25, 2015 07:25 PM
