problems w/ debaging
Old Jul 14, 2009 | 07:51 PM
r3n3gad3II's Avatar
so i cleaned my car today, and it was pretty hot so i also decided in debadging my car after the was.
i used the hair dryer and floss method which worked very well but i had some adhesive left on the car. I bought some goo gone and scrubbed the hell out of it but some were still left.
I read about using brake cleaner but i feel i already messed it up and didnt wanna use another chemical that might cause paint job problems.
http://i818.photobucket.com/albums/z...in/sticker.jpg
So this is how it looks now.
Old Jul 14, 2009 | 07:54 PM
Copperbottoms's Avatar
try heating it up again, apply a bit more goo-gone, then go at it w/your fingernails. Careful though, cus if you do it at too sharp an angle you risk abrading the paint (you can feel it when your nails are "scraping" at the paint anyways). Worked for me.
Old Jul 14, 2009 | 08:09 PM
JwongTLS's Avatar
put some goo gone on again and lit it sit for a bit
if that doesnt work try clay barring
GL
Old Jul 14, 2009 | 08:56 PM
greco9885's Avatar
definitely DONT use your nails. it will scratch the clearcoat, it can even take a chunk of it off. let the goo gone sit on it for like 15 seconds then wipe it off
Old Jul 14, 2009 | 09:17 PM
Clark_TL's Avatar
the marks are from oxydation... if you cant get it on your own, then the dealership will have "adhesive remover"(?)
Old Jul 14, 2009 | 09:22 PM
ifirahse's Avatar
SlammedOnKonis
use a blowdryer, then scrape it off
Old Jul 14, 2009 | 09:47 PM
AnthraciteAspec's Avatar
RPF1+RS3 FTW
Thats nothin! Just spray the goo gone all over it and let it sit for a few. I stick a rag underneath the area where I am applying the goo gone so it doesn't drip down. After you let it sit for a minute, wipe it off. Tada, done!
Old Jul 14, 2009 | 09:50 PM
csmeance's Avatar
use some bug/tar remover try letting it sit too!
Old Jul 14, 2009 | 10:52 PM
r3n3gad3II's Avatar
thnx for all the response. next step ima take is the bug/tar remover. i actually reheated and applied a whole lot off the goo gone and the picture above is still what it looked like.
but again thnx guys
Old Jul 14, 2009 | 11:15 PM
6MTProwler's Avatar
Death Before Dismount
Its doable dude, it takes patience and alot of goo gone. When I did this I spent well over an hour just getting the adhesive off. Just keep at it.
P.S. I used almost boiling water.
Old Jul 15, 2009 | 01:14 AM
Timb227's Avatar
Fear and Loathing in my
Bug and Tar remover works wonders. I had the same problem but then I used the bug and tar remover, let it sit...then use some elbow grease. It'll take it right off. I tried and tried with the goo gone, but it didn't do it.
Old Jul 15, 2009 | 01:39 AM
Yea, if you scratch at it and you have whore claws. Your nails are perfect for getting under the stuff, and soft enough that they won't do any harm to the paint. You don't have to go at it like you're scraping them on a chalkboard...
Old Jul 15, 2009 | 02:39 AM
mltk53's Avatar
I can't find my garage
i remember someone from the tsx forum saying that he used a clay bar and it worked like a charm
Old Jul 15, 2009 | 07:24 AM
Laxplaya11385's Avatar
i agree. I say claybar it. And while you're at it, you can also claybar the rest of the car
Old Jul 15, 2009 | 09:14 AM
Fuzzbutt's Avatar
From: Pittsburgh (Home of the Stanley Cup Champions)
I have used WD 40 in the past to safely remove adhesive.
Old Jul 15, 2009 | 10:43 AM
CarrieLynn's Avatar
^ truth
WD-40 pen FTMFW!!
Old Jul 15, 2009 | 02:16 PM
paz840's Avatar
clay wont work
...try a mildly abrasive polish like scratchx or optimum polish and work it on the area until the adhesive is gone
Old Jul 15, 2009 | 03:48 PM
JerZDevil's Avatar
like others have mentioned, WD-40 and a heat gun/hair dryer. It took awhile, but it worked.
Old Jul 15, 2009 | 03:53 PM
Jays_04TL's Avatar
SSM Sport Shifting
I used 3M Adhesive remover. (clear coat safe)
Worked like a charm for me
Old Jul 15, 2009 | 05:07 PM
218TL's Avatar
use a steel brillo..cuts that shit right out
SidhuSaaB
May 30, 2020 12:40 AM
Fool
Mar 10, 2016 08:42 PM
12vancover
Oct 16, 2015 12:04 PM
Matthew Purpura
Sep 25, 2015 06:10 PM
MikeJM310
Sep 24, 2015 07:24 PM
