Problem
Old Jun 6, 2005 | 05:10 PM
ahgil's Avatar
master tl
Problem
Hey anyone take off the plastice piece under their car the piece just behind the bumper cause after i lowered my car that piece is scraping everywhere and does it nessary to have it there
Old Jun 6, 2005 | 05:30 PM
Repecat's Avatar
Gratis dictum
I believe you are talking about the air deflector. That item deflects air up into your engine compartment to assist in cooling the engine. If removed, your engine may overheat which will just be the beginning of your troubles with the car. I wouldn't touch it.
Old Jun 6, 2005 | 05:32 PM
adner's Avatar
That piece (if you are referring to the piece that is about 3-4 feet long) actually redirects air into the underside of te engine compartment.
If you remove it, I would expect the engine to run hotter.
I notice another plastic piece under the front bumper that is about 1 foot long. I think that would be used to mount the a-spec kit.
Old Jun 6, 2005 | 06:35 PM
crazymjb's Avatar
Tighten it?
Old Jun 6, 2005 | 06:37 PM
caball88's Avatar
how low did you slam the ride? if u lowered it that much your ride must be harsh as hell(so expect lots more rattles to develop). that piece underneath the car does have a purpose so removing it would not be wise.
Old Jun 6, 2005 | 07:15 PM
pettydw's Avatar
The part has two purposes: 1) Create a low pressure area behind the radiator for improved cooling, and 2) reduce airflow under the car to lower drag. It is designed to take some abuse, so occasional dragging will not hurt it. My car is stock and it still drags on some driveway entrances, despite my trying to avoid it by angling and going slow.
Old Jun 7, 2005 | 04:38 PM
ahgil's Avatar
master tl
icici so i am not going to take it off then haha i am not slammed too low it just that i have to drive downtown area all the time and the bump are pretty crazy so i will scrap it sometimes haha
thanks for the help guys
Old Jun 8, 2005 | 07:46 AM
TBone2004's Avatar
Team Anthracite Member
looks like it all has been said already. Years back my sister had a Transam and tore that plastic piece off somehow...car would always run hot after that - had to buy a new one and replace it. Seems like a lame piece, but apparently it does its job.
SidhuSaaB
May 30, 2020 12:40 AM
Fool
Mar 10, 2016 08:42 PM
12vancover
Oct 16, 2015 12:04 PM
Matthew Purpura
Sep 25, 2015 06:10 PM
MikeJM310
Sep 24, 2015 07:24 PM
