Possible lemon in all 07-08 TL?
Old 03-30-2008, 07:07 PM
#TeamBoosted
TSXinity's Avatar
I took my 07 navi TL in for a possible defect of the climate control. My climate control seems to be acting up. When the temp. is set to "low", really cold air blows out. As I turn up the temp. all the way up to 86, REALLY COLD air still blows out. The next temp up is "high"...so when high is activated, the hot air starts coming out. Then when i lower the temp down to 70, really hot air still comes out until i hit "low". A/C is set to on btw. The tech people said they could not fix it and don't know what to do. They did all sorts of tests. They then said it was NORMAL because when they pull out a brand new 08 TL with 3 miles on it, it seem to do the exact same thing. I went up there and checked on the new cars for myself and they were all doing it. I never had a problem before and this started a month ago. Sometimes mine also puts out cold air on the driver side and hot air on the passenger side even when 'DUAL' was NOT activated. Can you guys confirm this in your cars to see if yalls are doing it? Check to see if cold air starting at "low" will still be cold at exactly "86" degree setting.
Also I just now noticed that our TL's back doors don't have speakers on them...why is this?
Old 03-30-2008, 07:41 PM
csmeance's Avatar
Received 1,989 Likes on 1,412 Posts
you probably have a bad logic board in the component that tells the system what to do. (if navi, the clock display, if non-navi, the radio screen)
the rear doors don't have speakers as the ELS system in the TL was meant to be under the BOSE system in the RL.
Old 03-30-2008, 07:44 PM
NC-Grayson's Avatar
i doubt this helps but i have the same problem on my 02 tl-s. but since i don't have dual, i don't have that problem, just the one when i turn the temperature up and the air blowing out stays cold, and vice versa.
Old 03-30-2008, 07:45 PM
umaya87's Avatar
sry to hear that. I have non navi 07 and dont have that problem
Old 03-30-2008, 09:40 PM
all work and no play
MWalsh9152's Avatar
I have an 08 TL-S and dont have that problem either
Old 03-30-2008, 09:44 PM
VQPower37's Avatar
i have an 07 tls and i do not have that problem ... seems like an isolated incident in a few of the TL's made at a certain time
Old 03-30-2008, 09:58 PM
2010 CBP SH-AWD
schill38's Avatar
No problems here, 08 TLS
Old 03-30-2008, 10:10 PM
Acuras Only in
shooter's Avatar
I hope this is not true for ALL Tls .. LOL .. so far so good on mine .. (knock on wood) .
Old 03-31-2008, 02:35 AM
94 DC4 RS LSV/Turbo
stillhere153's Avatar
07 tl-s no problem here... did you try it with the car warmed up...
I always hit the voice button set the temp at 75 and roll... you should check the mode... if you are on that auto (which sucks by the way) I would understand the crazy temps...
(don't believe it is a lemon tho )
Old 03-31-2008, 01:32 PM
stgdsie's Avatar
I have an 07 tls and i have the same problem you are referring to.
Old 03-31-2008, 02:31 PM
tclavell's Avatar
'07 TL-s, no problems here as well.
Old 04-02-2008, 07:18 PM
#TeamBoosted
TSXinity's Avatar
I am at 21,000 miles in my 07...maybe it has something to do with it later on in the mileage or that the climate controls been used so much?
Old 04-02-2008, 08:51 PM
KGB11's Avatar
Maybe it just takes some time for the climate control to kick in and for it to start blowing warm air. After 86 it probably goes into another cycle, something like high. Have you tried waiting a few minutes for it to warm up/cool down?
Old 04-02-2008, 09:30 PM
SFC, US ARMY AVIATION
chrissix's Avatar
Let me guess, you are doing this check in the middle of the day in direct sunlight?
Old 04-02-2008, 11:12 PM
flynhonda's Avatar
My 04 does the same thing, but its not all the time...
Old 04-03-2008, 07:56 AM
jime's Avatar
My 04 with 67,000 miles also does the same thing, but not until the last 6 months. I purchased a thermometer and clipped it to the vent. After the car cools - say at 70 degrees, the vent temperature keeps decreasing even if I increase the temp setting. The fan speed just goes way down. This continues until the I get the temp setting to MAX HOT, then hot air comes out. So I can be going along feeling very cold, with the temp setting on about 80, and the air coming out of the vent at 52 degrees.
I think that the "mix" feature (mixing hot and cold input air) seems to not be working. I am going to bring the car to the dealer in at my next oil change as it has an extended warranty.
Old 04-03-2008, 08:48 AM
06 WDP / 07 WDP Type-S
Be-in my TL's Avatar
That sounds very odd. I have both 06 / 07 S, and neither have that problem. You may just need to warm up the car, that is what I would do before wasting time at the dealership.
If your engine isn't warm, even at HOT, the vents will be blowing cold / cool air. You have to let the engine produce some heat for the fans to blow "warm" air.
Old 04-03-2008, 09:29 AM
jime's Avatar
Clarification to my previous post - after driving the car long enough for it to cool the interior on a moderately warm day - say 72 to 74 outside, then setting the interior temp up to 78, the air coming out of the vent will continue to get cooler and go down to about 49 to 52 degrees.
Old 04-03-2008, 09:44 AM
rmaiel's Avatar
'07 TL with Navi
and don't have that problem.
So what now ?? When they say they don't know what the problem is, that means they will need to escalate it not just say "we don't know. Go away !!"
Old 04-03-2008, 12:37 PM
it's me, Alan Rickman.
timmahh's Avatar
No problem on my car either; were you using auto climate control ?
benny_jdm
01-31-2016 06:15 AM
IIDXholic
10-08-2015 07:53 AM
carz0159
09-20-2015 06:11 PM
Abe_Froman
09-16-2015 01:27 PM
Quick Reply: Possible lemon in all 07-08 TL?
