Please help with back turn signal
I love TL so much that I want to return to Europe (in 8 months) with 2005 TL. Unfortunately, there is a law out there which does not allowed to use red turn signal. Please, advise me how to make it look more amber. Thanks
The whole housing is red, so my guess is that you might have to customize the whole tail lamp housing which isn't easy. If there was an aftermarket ones, it might have been a lot easier.
Good luck with it anyway.
Dan
Dan
Head a da Family
Seen a recent MB, BMW, VW, SAAB, VOLVO, JAG, without them ?
I Know !!!!!!!!!!!!!!!!!
You should rewire the reverse lights to allow a dual filament bulb. There are companies that make 1157 bulbs that have two different color LEDs. SO.........
when you put the car in reverse the bulb will light up with the clear whit LEDs
when you put on the Hazards or use your turn signal the bulb will flash the amber LEDs
This way you won't have to modify your lenses and use the clear reverse lenses
Sounds crazy, but it might work
-Chad
-Chad
-Chad
-Chad
I love cars!
-Chad
-Chad
Not a Blowhole
Contact Honda/Acura. Many cars have export parts/versions. The Corvette has for many years had special amber lenses for its dual round tail lights, and even the license plate mounting space can be had in the skinny Euro plates..
Can someone do a photochop of a TL with amber turn signal lights? I have found this uniquely American obsession with red turn lights distressing and is a feature I miss from my 2G TL. I think it'd be interesting to do this modification.
Previous Owner
Originally Posted by fast-tl
Very clever solution. To simplify, I'd just swap the turn signal into the reverse light housing and use an amber bub. I'd put the reverse bulb into the turn signal housing and if you're being picky, use a higher wattage bulb to offset the reverse lights being in a red housing.
How would the drivers to the side of you see that you want to turn into their lane without being semi directly behind you?
Ask Rockblocker. Maybe he can make some colored tail light film for you, kind of like the smoked ones that I just put on.
Previous Owner
Actually he has yellow colored film for the headlights. Have him cut it into the shape of the tail turn signal. I don't see why you can't put those on the back turn signals and make it orange? won't be a true amber color, but much easier than the re-wiring of the reverse light and stuff.
I slow down for COPS
it cannot be done half ass.
i sent many cars to Europe in the past and the back up light solution is very common. then, an external back up light is mounted in or below the bumper (so is a red fog light which is also required in most European countries)
old tread by the way.
andysinnh
09-05-2015 11:38 PM
Mugen TSX
Eastern Canada
09-01-2015 11:05 PM
