Passenger Side View Mirror Problem
Old Sep 28, 2013 | 12:53 AM
rohanq35's Avatar
Chicago's_TL
Hey guys, I've been having a problem with my passenger side view mirror for weeks. My drivers mirror work perfectly, but the passenger side does not want to move when i use the arrows. When i reverse, the mirror will turn but then it will not go back to the regular setting. I have to move it back manually with my hand. I checked other threads but there is no one having the exact problem that i am having, so i would really like your help guys. Thanks
Old Sep 28, 2013 | 01:00 AM
asma123's Avatar
Do you hear any sounds from the mirror when you try to move it with the button?
I think it might need a grease job.
Old Sep 28, 2013 | 01:02 AM
rohanq35's Avatar
Chicago's_TL
I did not notice, i will listen in the morning and see
Old Sep 28, 2013 | 01:13 AM
zubi23's Avatar
if you hear clicking while its tilting and if your still under warranty, the dealer will fix it for no charge. This happened to me too and the dealer fixed it. I think its a common problem. For me, it mainly happened in cold weather.
Old Sep 28, 2013 | 01:17 AM
rohanq35's Avatar
Chicago's_TL
Ya, i don;t have warranty on the car anymore. I will listen for the sound tomorrow
Old Sep 29, 2013 | 12:08 AM
rohanq35's Avatar
Chicago's_TL
Update: The mirror does not make a sound when you move it. It will tilt down automatically when you reverse, but then will not move with the arrows.
Old Sep 29, 2013 | 01:44 PM
rohanq35's Avatar
Chicago's_TL
BUMP! Need Help Guys
Old Sep 29, 2013 | 06:26 PM
Will Y.'s Avatar
Registered but harmless
Does your windshield washer pump work?
- If "yes," the mirror actuator may need replacement.
- If "no," then the #20 fuse (7.5 Amp) in the driver-side underdash fuse box needs to be replaced with a 10 Amp fuse per TSB, as that fuse controls some movements of the external mirror and seat motors as well as the washer pump and auto-dimming rear view mirror.
Welcome to AZ.
Old Sep 30, 2013 | 08:58 AM
rohanq35's Avatar
Chicago's_TL
That's probably it, i can't move my seat forward when i'm sitting down. Thanks!
Old Sep 30, 2013 | 10:39 AM
MarcoNorthPolo's Avatar
KCCO
Always check the fuses first!
marcelft
Jul 10, 2018 06:17 PM
Rocktman1
Oct 31, 2015 02:33 PM
sockr1
Oct 1, 2015 01:31 AM
mc1114
Sep 11, 2015 05:50 PM
dre707
Sep 8, 2015 08:32 PM
