Overhead map light assembly
So I'm driving today, and the entire overhead map light assembly by the rearview mirror fell out of the roof, and is hanging by the wires. I looked, the 4 bolts that hold it up are still attached to the roof, and all 4 of the plastic tab mounts are broken. I don't know if the heat caused it or what.
I have an appointment with the dealer tomorrow to get it replaced. Real nice for a 2008 car with 8,900 miles on it to have this crap falling off already.![Roll Eyes](https://acurazine.com/forums/images/smilies/rolleyes.gif)
Has anyone else had this happen to them, or did I just get the freak occurance?
![ugh](https://acurazine.com/forums/images/smilies/ugh.gif)
Not major, but still disappointing. The plastic on the tabs crumbled when I looked at it (some of it is still behind the bolts mounted to the roof), not sure if was defective or the heat fried it. If it was heat.....makes me worry about all those cracked dash issues I've seen. ![ugh](https://acurazine.com/forums/images/smilies/ugh.gif)
I know, I'm hoping they don't give me any trouble over it. Like trying to say I broke it, because the assembly is expensive.
Well, my first service expierence hasn't been a good one.
I get out there, they look at it, and then tell me they don't have the part. They have to order it, and I have to come back Monday. They didn't know when I called they didn't have it in stock?
It says they ordered a HFL unit, is that the entire overhead console?
Unless I'm looking at it wrong.
![](http://www.acuraoemparts.com/delray/jsp/catimgs/14sep8_b10.gif)
WDP Director of R & D
No, you are completely correct. The HFL and housing come together so yes, they should have ordered you the right thing. Now, if they ordered the wrong color like they did with mine you will be waiting longer.... :-)
My 04 TL was less than 6 months old when and I removed the housing and other items to fix the creaking noises from the headliner. All 4 tabs were cracked etc just as you described. I installed 4 small metal angle brackets to secure the housing - didn't feel like taking it to the dealer just yet to have them fudge up other stuff etc..
Jump near 4 years later when I do take it in for my final warranty visit to have the HFL module replaced per the TSB... This is where I find out it's the entire housing. While the part was on order I removed my angle brackets previously installed and they replaced the housing/HFL once the right color arrived.
I would bet that most TL's have this same problem - the housing just hasn't fell down as of yet. The "angle" of the cracks on my mounting tabs was the only thing holding mine up.
I feel more so that it's from over tightening of the screws and brittle plastic - and - even though you may not think it, their sounds to be a little "flex" in that area of the roof when driving over angled/uneven surfaces etc.. When I pull out of my driveway just right I can here small creaks from the housing etc.. I'm sure it's only a matter of time before the new housing requires support.
Cheers
Cheers
Cheers
Car got fixed today, all is well. You DO have to order the HFL unit to get the housing for the map light and everything else.
Hope it doesnt happen to you guys out of warranty, the part alone is $520+.
rockyboy
12-06-2022 02:29 PM
cycdaniel
12-17-2019 10:58 AM
rockyboy
01-25-2016 06:00 PM
