OK you 6MT people......
Man of God.....
When you are "running the gears" Do you hit the VSA button? On dry, clean roads of course. Sometimes I wonder who is better - me or the TL? At controlling its power to the pavement.....
Also care to share your launch technique???
RBP > WDP, NBP, SSM etc
1 Post
I haven't touched it, only had the car 8 days now...this is my first stick car so I"m still trying to get used to driving stick
had troubles last night getting into my friend's driveway which had like a 2" lip on it and stopped right at the threshold so that i dont scrape my bumper and stalled TWICE trying to get up it LOL YES I'm a newbie stick driver
but no haven't touched the VSA button
The only time I have turned it off was in the snow, as the car had problems moving with it on.
I dont drag race, but if I was going to, I would turn it off.
Actualy, I would rather it be off all the time, I have no use for it.
Brett
Brett
04 NBP 6MT
Turning the VSA off adds at least 15 whp.
However, the car shifts the same with it on or off. VSA can cut engine power or apply the brakes, it does not control the shifter or the clutch.
I usually leave it on, since its a pain to turn it off every time I start the car and it isn't ridiculously intrusive. I've only managed to light it up 2 or 3 times and once was on an uphill start in the rain.
Team Nighthawk Mambo King
I shut mine off all the time, even on the Ody my wife does it unless it rains (she feels secure) but I want total control of the car...and I like the little triangle on the dash makes my dash looks so "especial"...
Registered Member
Turning off the VSA adds no extra horsepower or torque to the engine. It can't.. such things are a factor of the engine and ECU's state of tune. What it does do is keep the VSA from anticipating a "situation" or "condition" and thereby interferring with your operation of the vehicle.
If you turn the VSA off, you can come out of the hole harder (this means launching from a standing start, people), regulate wheel spin with clutch (if you have one) and throttle, and shift rather agressively. Bottom line is with it off, the car will definitely launch and accelerate harder. With a manual and just speed shifting, you will be able to get rubber in the first three gears.
Man of God.....
OK, How about your launch technique? Like do you start in 2nd gear? Or rev. up to around 3500rpm and feather the clutch in 1st gear? Whats you big secret?
I now have 3500 miles on my 06 MT and If I try to "bang" third gear real hard it will still slip!! First and 2nd will chirp and has lots of power (with VSA OFF), no problems with those 2 gears but its like 3rd gear cant keep the weels spinning and then motor starts reving real high but not the wheels (thats not good!!). Damn cheap acura clutch
The DVD-A Script Guy
I've always left it on because I figured for dry weather, "regular old" driving it would not make a any difference since I don't usually push the car to any slip.
But just for fun I started turning it off. Now I think I have gone crazy because it seems like getting the car rolling in 1st gear is easier. I don't mean hole shots, I mean regular, normal, nothing special starts seam easier.
Am I crazy ? Is it all in my head? I never would have thought that VSA would do anything at all in that situation. Anyway, I've never seen the VSA light blink (except in snow) either when I start in 1st. To me the TL has been a tough car to get used to for engaging 1st. Am I nuts ?
By speed shifting do you mean not letting your foot of the gas when shifting, or just shifting as fast as you can and still letting off the gas? I'd be afraid to take my engine to the redline, push the clutch in, shift gears, and not back off the gas slightly. If I wasn't fast enough, or the shifter hung up somehow, I'd worry about the engine blowing up. I know the rev limiter should prevent this from happening, but I just don't like to abuse my car.
Registered Member
Speed shifting is just normal shifting, only it's done VERY fast. What you're talking about in the first part of your first sentence is "power shifting". When power shifting, you shift VERY quickly, using the clutch, and keeping your foot floored the entire time. Speed shifting is what you descibed in the second part of your first sentence.
As for taking the engine to redline between shifts, this is not always desirable in drag racing. What you want to do is take the RPMs to the point at which when you shift to the next higher gear, your engine will be at or just beyond its peak torque curve and still building its horsepower curve.
Hope this answers your questions.
Zonian22
11-14-2015 01:20 PM
MrHeeltoe
79
10-14-2015 08:47 AM
