View Poll Results: Type of oil
Acura Spec 5w-20
19
18.81%
Name brand normal oil 5w-20
11.88%
Mobil 1 0w-20
31
30.69%
Other Full Synthetic 5w-20, Amsoil, Redline, Havoline
25
24.75%
Mobil 1 5w-30
14
13.86%
Voters: 101. You may not vote on this poll
Oil type selected
Motor Oil YOU will use on your Baby?
Mobil 1 recommends their 0w-20 for Honda and Ford engines. Their website confirms this, I called and they say no plans to release 5w-20 synthetic.
use amsoil then if mobil doesn't offer 5w-20. the price is about the same, maybe a dollar more per liter but amsoil is fully synthetic. there is some debate whether or not mobil 1 was fully synthetic.
Amsoil 5w-20 is a Group III based oil which would not be a full synthetic but a highly purified dino. Mobil 1 5w30 is a Group IV oil made with PAO which is considered a true synthetic. Check out BobistheOilGuy forums for more info on this.
WDP Director of R & D
I just changed mine at ~ 4500 miles. Felt that was long enough for the break-in oil interval (MID was 50%).... Decided to use Castrol GTX 5W-20. I would prefer Mobile 1 but not a fan of 0W-20 for 100+ temps here in TX. OK for winter but have my "fears" for summer - call me old school. Not sure of any issues with 5W-30 behond gas mileage either...
I'm hoping in the near future we will see more Synthetic Blends etc. in the 5W-20 vis. I've been a Valvoline and Mobile-1 user all my life.
GTX is a very good choice for conventional Oil. Can't go wrong there. I use Mobil 1 5w-30 with K&N Oil Filter. The oil cap says 5w-20 but the M1 5w-30 is thin compared to other 5w-30 oils and is borderline 5w-20 range.
Since the clearance specs haven't changed since Honda/Acura specified 5W-30 I believe their motive for the lower 5W-20 oil is purely for gas milage and faster warm up
times. While this is not a bad idea at all I will probably go with what I've been using for years now which is Amsoil's 100% PAO 0W-30. It is a very fuel efficient oil, is guaranteed for 35,000 miles or one year, has the best additives et. If the dealer gives me any problems I will go either with 0W20 Mobil 1 or Red Line 5W-20.
Craig
Craig
And how do you really know you are getting Acura Spec 5-20W oil, unless you buy it in the original containers and do your own oil change or watch it being done using those containers? Not that I don't trust dealers and their service departments, but I was a parts manager for 15 years and there is usually only one tube coming from the bulk oil container, meant for all the different and varied requirements of the cars being serviced. Not that an Acura dealer would be guilty of this.
RonA,
Yes usually dealers get their oil in 55 gal drums or a Tote which is 250 gallons. This saves them money by buying in large quantities and simply cost of individual quart containers. Honest dealers will get the factory spec oil but just in a larger container.
Yes and some will use one wt oil for all the cars they service regardless of what wt oil
the factory recommends for each engine they produce.
The important part is that they use the correct SAE/API rating. For example the latest
is SL, S stands for spark or gas engine, L is the latest and highest grade available now.
When the OEM's need better oil the next grade would be SM.
Craig
Craig
Option?
If they blend a synthetic thats 5W-20, 0W-20, or IMHO a 0W-30
go with it if you prefer Valvoline.
Make sure it meets the Acura API spec for the oil.
Craig
Craig
Originally Posted by EulisCool
is it true that once you use synthetic you cannot go back to regular non-synthetic oil?
Myth, go back and forth and in 99% of cases mix 'em in the crank case.
Vandy
Very true. Mechanics and servicing dealers don't want anybody using synthetic oil as
the wear factors are minmal compared to dino oils. They want you back for their services.
Chet03TLS,
It is true that the new class III oils are petroleum based stocks. However, they have
improved the additives to the point that they are very close to PAO (pure synthetic)
in performance but won't last as long as a full 100% synthetic.
Craig
Chet03TLS,
Craig
Retired MOD
1 Post
I have used all the above mention including redline....
My favorite now is 10w40....somehow the engine likes it, it starts good, good power, no hard idle, quiet valves.
Remember my car has over 100k miles.
I also switched from the most expensive $9 a bottle synthetic 5w30 to the cheapest $84 conventional oil.....is just not worth it, except the redline I would switch every 5k-7k miles....this one I switch ever 2k miles.
HP-1004 or HP-1005 (oversize) ?
Thanks, for the update,
The M1,s are $12 + Tax here and I can get the K&N's for $8.97 w/free shipping from
http://www.ajusa.com/cgi-bin/knfilters/search_vehicles
Have a few cars to do so it saves a bit by going with the K&N's
I have been told that the WIX oil filter is the best. Costs about $7.00. So for me its Mobil 1 0W-20 and the WIX oil filter. By the way just got the Mobil 1 at Strauss Auto Stores for $3.99/quart.
I might try the HP-1005 next. Anyone with with any experience with this oversized filter?
K&N filters are built like a tank. Super hard and heavy. No orange cans for my car.
I'll be using Mobil 1 0W-20 and NAPA Gold (WIX) filters.
5W-20 is what Honda/Acura recommends, not requires. So long as you stay at or above the top number -20 - (within reason of course), and the oil meets API standards, there shouldn't be any issues.
Too many myths about oil, filters, and change intervals in the world.
mugen_kid
11-13-2015 10:38 PM
IIDXholic
10-08-2015 07:53 AM
HydrasunGQ
09-14-2015 10:14 PM
