Oil Life 50% @ 3200 miles
Re: Oil Life 50% @ 3200 miles
Originally posted by perrotta
doesnt honda recomend under normal driving 7500 miles to the change? i know mine does. and if they recomend it why not? ive been doing it for 131,000 miles now ind shes running perfectly!
3700 miles, 50%.
By the way, fsttyms1, congratulations on turning 130k! Time to consider a new TL.
Originally posted by neuronbob
3700 miles, 50%.
3700 miles, 50%.
Most modern oil on modern engine can last MUCH longer than 3000 miles. On my Maxima I go 10,000 on Mobil 1 synthetic. On my Integra I go 5,000 on Castro GTX. All of this is based on repeated oil analysis. Jiffy Lube would love for you to change it ever 3,000 miles... they make more money that way. But you don't need to do it...
Moderator Alumnus
Re: Re: Oil Life 50% @ 3200 miles
Originally posted by Z Factor
Just keep in mind that you do not have to wait for the computer to tell you when to change the oil. I think every 3-5k is a good time with a filter change each time. Personally, if I owned my TL, I'd now switch it to Mobil1 Synthetic, but since I only lease it I'll be using dino oil.
Re: Re: Re: Oil Life 50% @ 3200 miles
Originally posted by rets
Do you know how to reset your minder to 100% by yourself if MID doesn't show up the SERVICE DUE info?
Of couse, I'd like to see the look on their face when you try; also want to see them try to charge you for it. <VBG>
Originally posted by dulnev
Not only do you not need to, but the TL manual says in no uncertain terms that you MUST keep the original oil for the first 7,500 for proper break-in.
I have 2000 miles and it shows life at 80%. Thats fine.
I typically change oil at the recommended 7500 mile intervals for regular oil and 10000 to 12500 for Mobil 1 oil. Been doing this for 30 years and heve NEVER, I repeat NEVER, had an oil related problem...NEVER. All the hype about 3000 miles intervals is crap unless you are towing or ubder some strenuous conditions that no one ever travels under. Change it at 7500 miles... and if it will make you feel better, at 3000 miles send me the money you would have spent on the oil change... cuz it will do as much good... SAVE YOUR MONEY...AND TIME!!!
Go to the mid display ...show oil life... and hit reset for about 10 seconds... It will reset to 100%. This procedure is in the owners manual.
'06 750Li Sapphire/Creme
What, not synth?
People seem to be lumping synthetics in with traditional oils in these replys. Pretty certain that everyone KNOWS that synthetics were designed to go 10K, right? The traditionals go from 3K to 5K generally before they start to breakdown. In regards to the sensors...Benz & BMW have been doing this for quite some time. It's actually a pretty simply analysis by the engine of vicosity and transparency. Some sensors even detect metal content. These systems therefore will provide a more personal feedback based on your driving style (right). In some cases, it is simply a straight mileage-based measurement. I have no idea which system Acura uses in these cars but did think that the oil was synthetic from the start. From what I'm reading here, I guess I was wrong. If it's not synthetic, I'm changing it to the synth at the 7500 mile breakin mark.
Re: What, not synth?
Originally posted by honda loyalty
Mobil 1 best oil you can get.
but this will open up a lot a discussions
http://www.unofficialbmw.com/all/misc/all_oilfaq.html
mada51589
05-03-2022 08:54 PM
asahrts
09-04-2015 05:55 PM
