oil life %
oil life %
Hello all,
Just a quick question. On my new TL I have about 400 miles and I just notcied that the oil life gauge says 90%! Is that about normal usage? At that rate I'll be down to 0% oil life at 4000 miles, which according to posts here is a little too soon. What do you think?
-Steve
-Steve
Originally Posted by screaming
Hello all,
-Steve
-Steve
you are driving too aggressively.
its normal, modern engines can survive much longer than the 3K you are accustomed to. if you do a search you will notice that people perform their first oil change anywhere from 3-7 thousand miles depending on driving conditions.
I am at 90%, but I have 1050 miles. With a 600 mile trip in there. By translating that out, I won't need an oil change until the 10,000 mark (no way).
Do you make many short trips? How many starts of the engine everyday? Starting is the hardest on your engine.
Originally Posted by ensley696
80% @ 1400 miles on mine. I'm wondering if the heat has anything to do with that though. I admit, I do drive a little aggressive at times, but for short periods only. I avg about 23-24 MPG.
Yeah, I've been trying to not drive aggressively, really. My RPMs rarely go into the 4k-5k range though I've had a couple 'oops!' and get into the mid-high 4k range (Hey, it's not my fault the engine's so quiet!
). I have the 6MT and it took me a while to get used to the clutch with stalls and jerks abound!
Most of my driving has been city-type driving too, since I haven't gone on any long trips yet. I would say that I start my car 5-6 times a day, on average (coffee, work, gym, errands). Still normal? Am I setting myself up for a problem 5-6 years from now with oil leakage, etc by being 'too aggressive'?
-Steve
). I have the 6MT and it took me a while to get used to the clutch with stalls and jerks abound!Most of my driving has been city-type driving too, since I haven't gone on any long trips yet. I would say that I start my car 5-6 times a day, on average (coffee, work, gym, errands). Still normal? Am I setting myself up for a problem 5-6 years from now with oil leakage, etc by being 'too aggressive'?
-Steve
I changed early like you said (same philosophy) now I am watching MID - I have put an additional 5500 miles since that first change and the MID is now reading 40%.
Normally I would be changing again, but many here say to follow the MID - so confusing. I suspect as with most things it is 6 this 1/2 dozen that (something like that) and we are splitting hairs. I don't know what to think. I know I will not let it go beyond 7000 miles regardless of what my MID says - cause it could be wrong!
Originally Posted by cvajs
new car? change at 600 miles, 1500 miles, then every 3-5k depending on oil/filters used, how you drive, and environment. the early changes flush out the break-in particles.
Originally Posted by DMZ
2100 Miles, 50%, a mix of about 25% highway, 75% city
-Steve
Acura says to follow the MID..... So, I get the oil changed at the dealer. Guess what they stick on my window- a little decal to remind me to change the oil after 3,000 miles. Too funny. I bet the dealer would like to reprogram the MID to read 0% at 3,000 miles. Regardless, I am over 5,500 miles since the last change and still at 30%. My conscious will not let me drive much more without changing the oil.
I'm still showing 90% at roughly 1,050 miles. There was one 400 mile day trip and a 200 mile highway/street day trip plus another 400 or so miles of mixed driving.
I'm NOT waiting for the MID to tell me when to do the first oil change. I'm doing the first change by 3,000 miles or earlier.
Regards,
Regards,
Regards,
Regards,
I changed to synthetic at 10k and am just following the MID now. I might have my oil analyized to make sure it's doing it's job at my next drain.
Regards,
Regards,
If honda gives us a oil life calculator. they must done some research and testing on the oil life span in this engine. And proven to be a highly reasonable algorithm. Their engineers are better than any1 in this forum saying such and such. I trust Honda not to put the oil life calculator on just because, so all their customers will phuck up their engines.
If some1 ran 3000 miles and showing 90% oil life, that’s a computer malfunction.
It sounds like the people that have the lower percent *used* per mile are doing a lot more highway driving than I am. Seriously though, should I be concerned about this, especially if I'm still in my break-in period?
-Steve
-Steve
-Steve
-Steve
Steve,
Your fine, don't worry about it. Your car is fine. Keep in mind it's summer so you will switch the oil out sooner then normal. Plus the city driver and starting the car 5 times a day contributes to it dropping sooner. I was worried at one point as well but then I went to the dealer and got to the bottom line.
goes against the MID and the manual. I wouldn't do that.
There are about 20 threads on this topic active at any given time:
Here are my 25 cents:
http://www.acura-tl.com/forums/showthread.php?t=89702
heh I just read that before coming back to this thread
Thanks for the info guys.. I think I'll wait it out until 3k miles and see what the MiD says. If it's low enough I'll just change it.. Especially since it's the *first* oil change anyway.
Thanks again!
-Steve
Thanks for the info guys.. I think I'll wait it out until 3k miles and see what the MiD says. If it's low enough I'll just change it.. Especially since it's the *first* oil change anyway.Thanks again!
-Steve
engine component flak will shed off as the engine seats. changing oil twice within 1500 miles helps protect against getting small particles past the filter.
i did not notice what my MID said after i changed the oil, % should have gone up with ne oil.
My 2c on oil change interval vs MID % indictator... since wear and tear in the engineer is mostly due to friction and heat, therefor I change oil and filter between 3k-4k miles. The car not driven hard but alot to stop and go commuter traffic.
Also, not much friction in stop and go traffic. However, 4K is probably a decent interval if you regularly are stuck in bumper to bumper situations - what has the Mid recommended to you by the way?
Originally Posted by Road Rage
This post was edited and ended up like it did anyway?
Oil Life
Actually city stop and go driving is considered "severe service".
I had 2400mi and was reading 70% oil life. Had to attend a funeral with alot of
slow driving on a 95 degree day. Oil life went down 10% in 20 miles as well as the
milage went down to 18 from 23mpg.
Craig
Craig
Craig
Craig
As i said before, many companies no longer define normal and severe, as it is confusing to most people. Ford went to 5K, which is the normal service life of a mineral oil - so when i see a used oil analysis (UOA) of most minoils, they are starting to go by 5K, so these much higher recs from the MiD make me nervous, and as i posted, I do not want to be the victim of a marketing guy's optimism that the quart is half full.
Summertime, summertime, sum-sum, summertime
Originally Posted by J RIDE 81
Steve,
If anything, my car warms up faster in the summer and gets the oil where it's needed faster than in winter.
So why would I switch the oil out faster in summer? Maybe because I drive more?
Road Rage? Comments?
Of course, I am in Florida so "winter" to me just means more snowbirds clogging the roads and making me drive slower.
Florida bumper sticker: "Welcome to Florida. Now go back to NY"
j/k I'm a transplanted New Yorker.
BTW, back on topic... I have 1000 miles and 90% oil life showing. About half suburban short spurts and half 25 mile runs up the Turnpike and back.
XP
IBankMouse
Jun 13, 2020 12:53 PM
