Oil Leak? 2007 TL
Oil Leak? 2007 TL
I had the car on my lift yesterday changing the engine oil. While I did my "big picture" look around under the car, I found what appears to be oil on the plastic "skid plate" that is secured under the engine.
I tracked where it appears to be originating from and it looks to be coming from some sort of black inspection cover that is held on by two bolts on the underside of the engine/transmission. I didn't pursue taking off that cover and investigating further as it was getting late.
Any ideas on what this "inspection" cover is and what is behind it and more importantly what the leak may be coming from?
The color of the liquid looks like the color of engine oil.
Thanks!!
Thanks!!
Pictures of said area please.
MobyDickDog (10-23-2012)
It's probably the rear main if it's coming from the inspection cover. Mine has a leak there too. It's never actually dripped so I'm leaving it until it gets worse or until the trans needs to be rebuilt. If you have a manual it's a little more important. If there's enough it will eventually destroy the clutch.
the overexplainer
requires dropping the transmission at least on a MT.
i cant say for sure how many people are affected, since it's not really noticeable until you take that cover off. pulling #s out of my butt, i'd say 25%.
it's not leaking enough on mine to register on the dip stick. I think i'm burning more oil than leaking from the RMS. Rate of loss is about half a quart every 5k for me. When i get my clutch changed eventually i'll get it replaced.
Thanks guys! I always get confused and turned around on Front Wheel Drive vehicles. I couldn't tell ya which is the front seal or the rear seal on a sideways engine. It sounds like from a couple of the responses that it's a seal. I may just end up taking it to the Stealership and have them take a look. I have an Acura Extended Warranty so hopefully this type of item is covered.
under what specific warranty? After market, power train, original warranty? I am interesting to know about this since this is kinda thing that usually happen to J series motor.
OP, was it in this same general area?
https://acurazine.com/forums/showpos...88&postcount=1
Happened on my 04 6MT shortly after having the PS safety recall done (coincidentally or not...). It never dripped on the garage floor and it stopped as mysteriously as it started....
Yep, that's the exact area where my oil was leaking.
I'm not 100% sure of which "warranty" it falls under. I have an Acura Warranty that expires in Jan 2015 and then there is the 6 year / 70,000 mile Powertrain Warranty.
I pick the car up on Monday and will try to find out what warranty actually covered it.
For what it's worth, I bought the car new in January of 2007. I currently have 42,500 miles on it.
Just curious, when did you have the Power Steering safety recall done? If you don't remember, have the dealer look it up.
I believe the power steering issue was accomplished August of this year.
About a month later they had to replace the Right front strut/shock assembly.
I see no correlation between a rear main seal and any of these 2 issues.
I can't prove it, but that's my theory. There are several of us who had the same leak, all after the PS recall was done. And I'll bet you also didn't have the leak until after the PS recall was done....
Read the Power Steering recall TSB (pp 7-8). They remove the rear engine and transmission mount bolts and jack the engine....
It really sucks for those who have an uncontrollable leak. It's a $9 part but $900 labor
I had this issue and got it fixed during a clutch job, it's the rear main seal. This is one area that I wish honda had designed the car easier to repair. People are correct, the part is $9, but the effort to get in there is high upwards to $900 in labor.
What's rear main seal?
First thing came to my mind was the transmission.
Our tranny is not like German one (one unit)
It's 2 pieces putted together, so there is a little leak in between.
Not a big deal though, it's normal
Is that what you guys are talking about?
OP is your car AT?
OP is your car AT?
^^^^no the rear main seal is use to prevent oil from leaking out via crank shaft that spin the fly wheel to create power and eventually move the whole MT/AT. It located behind the fly wheel so in other words you must remove the transmission and fly wheel (pressure plate is prefer term of AT) in order for a replacement. The part it self isn't much money since it just a rubber seal like your brake caliper piston but you have to remove alot of sh*t (like J pipe and remove the whole AT/MT, flywheel or pressure plate and clutch (in MT) in order to replace it. The labor for all of that removal is high therefore your labor cost is sky rocket.
MEKO (11-11-2012)
^^^yep they should be alright unless it gushing out like a water fall. My accord loosing about a quart for every two day so its real bad.
IBankMouse
06-13-2020 12:53 PM
4drviper
09-23-2015 09:00 PM
STL TL-S
09-23-2015 08:52 PM
