Oil filter accessibility
might be a silly question but:
Each time I change the oil I've always raised the car and removed the right wheel to access the oil filter.
Is that overkill?
I plan on buying a set of ramps and want to ask if the oil filter would be accessible without removing the wheel
Is that overkill?
I fill up (prime) the filter, and lube all around the filter and throw it on hand tight... If you need to take off the wheel you're either over tightening it or have fat arms
or muscular arms
reason I've been removing the wheel is to prevent spillage of fluid.
what I have been doing is placing a ziplock bag around the filter as im removing it to limit the spillage of oil.
Someone on the forum noted that in a post I read some time ago ( thanks, to whomever that was )
but, thank you all for the clarification.
Have a great day
mvp2765 (11-14-2013)
rcs86
08-02-2016 06:52 PM
