Oil change frequency
2008 TL base 3.2L
Last time I was at Christian Brothers, they did a full synthetic oil change. Did so early December '21, sticker says come back early May '22.
I haven't been back yet, and my oil life right now is 80%.
I haven't driven the car much, maybe at most 2000 miles since December...
Do I really need to change the oil again, or can I wait?
Typically in months, how long can we wait before requiring an oil change (if rarely driven)?
Although,I do agree with annual oil changes regardless of mileage.
Good for extra HP, right?Typically, I do 3-5K mile changes using OEM filters and conventional oil.
But my situation may be different from most--
--That's about my annual mileage since retirement
--I alternate cars summer/winter, so they get the once-a-year once-over (and monthly starts in off-season)
--I still have several more cases of conventional oil in stock
--None of them use even a pint between changes, but if the oil goes black it gets changed
--Mrs2TL drives about the same annual mileage.
So, whatever works for you...
Yeah, I'm one of those guys. Fresh oil
I change every 20K at Acura TL 2003 that yield once per year. Use "Mobile extended performance good for 20K" and filter good for 20K. At my pickup truck F250 LD I change oil every 3 years. Both interval I do after reading a lot.
Strange that you have completely different oil change interval ideologies that conflict one another between your two cars..
I drive pickup only for work and make around 6k per year. It yields 18k in 3 years. I have a dose comment from different forums saved and will copy paste here if need those 3 years are ok for synthetics. Somme comments are from reputable oil research facilities. For Acura "Mobil extended performance" say at can 20K.
Edit, synthetic oil gets acidic at a much slower rate than dyno.
I must admit that I add 1 quart of oil per month because of a leaking oil drain plug. Made thread about it https://acurazine.com/forums/third-g...n-plug-999971/ . But I had before Infiniti that I changed oil at 20k and I sold it at 254K where I owned it from 140K. The engine was fine.
Bump old tread. I do Mobil 1 extended romance. I do around 12-15k change interval or every 2 years on car and pickup. Nothing was wrong with 20k jet. Changing every 20k for 20 years now at multiple cars and none car had engine problem.
I've been changing mine mostly at 7500 miles with Penzoil Platinum, now that I'm past 300,000 miles, every 6000 miles with the same oil. Currently at 337,000 miles and the motor still runs strong and uses maybe 1/4 quart in between oil changes.
