offset
Old Mar 11, 2004 | 02:26 AM
digital_b's Avatar
offset
thinking about going with 18s, tsw slot to be precise. I think I mentioned that in another post and the tires.com guy told me 35mm offset would fit. several people then said no it probably wouldnt. the other offset is 45mm. what is the stock offset and will this 45mm offset fit? I really like those rims. they remind me of the hre 545s but are far less costly.
Old Mar 11, 2004 | 06:27 AM
vclune's Avatar
Re: offset
Acura 18's have 45mm offset 18X8.5
Old Mar 12, 2004 | 03:36 AM
honda loyalty's Avatar
45mm is your factory offset.
Old Mar 12, 2004 | 03:39 AM
adam209's Avatar
Re: Re: offset
the 18's are only 8'' wide not 8.5''
Old Mar 12, 2004 | 05:36 AM
dcarlinf1's Avatar
Re: Re: Re: offset
Wrong. I called the dealer to confirm they are 8.5". Another member on here also states that the wheels say the size (8.5") right on the wheel.
Old Mar 12, 2004 | 07:49 AM
vclune's Avatar
The Acura 18's do say they are 8.5 wide and if you choose to measure them they are 8.5 from bead to bead and 9.5 from edge to edge. I have an unmounted set on hand, so this info is as good as it gets.
Old Mar 20, 2004 | 12:11 PM
chiy's Avatar
Will rim that are 18x8 w/offset 43mm fit on the TL?
Old Mar 20, 2004 | 02:59 PM
vclune's Avatar
Sure, They should fit. That's only 2mm less offset than the ACURA wheels. 2mm only equals a smidget if you look on a scale (measuring stick)
neuronbob
23
Jul 16, 2019 10:48 AM
BreezyTL
Jul 26, 2016 12:52 PM
SinCityTLX
55
Oct 11, 2015 01:20 AM
Ratheruneeq
Sep 28, 2015 07:41 AM
bailey24
Aug 31, 2015 05:38 PM
