The Official "Does This Fit My Car?" Thread
#641
Auto Couture Status
To the gurus..
I have a 05 TL I just bought 20' rims for it (stupid me didnt check i thought they all universal.. I know im a noobz, got money to spend im gonna spend it!) ..
the dimensions are 20x8.5, 5x114.3, offset +45.... would it fit with my a-spec kit??
Thanks for the help
-DeZ
Thanks for the help
-DeZ
#642
94 DC4 RS LSV/Turbo
To the gurus..
Thanks for the help
-DeZ
Thanks for the help
-DeZ
#644
Well I'd rather not remove the bumper. I'd actually rather to install it and it take 30 min. to an hour and not remove a bunch of crap, if it means removing less things. So I can just pop the hood and install it without a lift or anything right? And should I sell my stock air intake?
#645
94 DC4 RS LSV/Turbo
My suggestion to you, return it
Removing the front bumper is a pita I know, but it does make the install easier
#646
Ok so is there like a diagram of how to remove the bumper? And what else is there to remove besides the bumper? I am getting:
"Injen Cold Air RD Series Race Division Intake Systems, Polished, 04-08 UA6 TL (CARB 04 Only), 2007 TL Type S, RD1482P"
From heeltoe, will it be easy and nothing to it? Or do you have a recommended CAI thats better/easier to install.
#647
I have 2007 style front bumper on my TL, I can't afford to spend the money and buy the Acura fog lamps: http://cgi.ebay.com/ebaymotors/07-08...=p4506.c0.m245 will the Honda 1's work ?
Are they the same dimensions, oval shape?
Honda lights: http://cgi.ebay.com/ebaymotors/03-04...d=p3911.c0.m14
#649
94 DC4 RS LSV/Turbo
http://www.youtube.com/watch?v=U1C5VJtetN8
#650
94 DC4 RS LSV/Turbo
they move the back of the wheel further out making more space for big brakes (ie. ur brembos)
#654
Year: 05
Model: TL
Trim: 5AT w/ NAV.
Color: ---
Item you would like fitment verified:
Current setup is 18x8.5 A-Specs with 245/40R18 tires, running on A-Spec suspension. Been thinking about purchasing a set of 19" Honda HFP 10 spokes. The specs for these rims are:
- 19"x8"
- 5 x 114 bolt pattern
- +55 offset
The 18x8.5 A-Specs are +45 offset. Since the HFP's are +55 offset, and 1/2 inch narrower, would the wheels looked "tucked in"?? Try to stay away from spacers if possible. What size of tires is recommended? The recommended tire size from Honda for the HFP is 235/35R19.
Also, would these wheels clear the Rotora BBK? I would assume so, but that +55 offset kinda worries me.
Thanks fitting guru!
Model: TL
Trim: 5AT w/ NAV.
Color: ---
- 19"x8"
- +55 offset
#655
94 DC4 RS LSV/Turbo
Year: 05
Model: TL
Trim: 5AT w/ NAV.
Color: ---
- 19"x8"
- +55 offset
Model: TL
Trim: 5AT w/ NAV.
Color: ---
- 19"x8"
- +55 offset
Ok if you would like to stay away from a spacer... then pass on that wheel, if your car is equiped with a rotora bbk you will need no less than a 15mm spacer... not only for it to look good but for it to clear the brakes...
#658
Follow this guideline
Year: 05
Trim: base
Color: ---
Example
Year: 2007
Trim: TYPE S
Color: Black
I'd like to know if i take type S tail lights and putt them on my 05 tl they would fit ,..do i have to make any hardware changes or wiring or it's simply plug and use ...also it is very hard to remove the tail lights
Year: 05
Trim: base
Color: ---
Example
Year: 2007
Trim: TYPE S
Color: Black
#659
94 DC4 RS LSV/Turbo
the tire size would render the car undrivable
Year: 05
Trim: base
Color: ---
Example
Year: 2007
Trim: TYPE S
Color: Black
Year: 05
Trim: base
Color: ---
Example
Year: 2007
Trim: TYPE S
Color: Black
taillights are real easy to remove, search on the forum its been done many times
#662
So fitting guru, I have another request of you...here it is:
I want to get ATLP J-Pipe Version 2, for all 3.2L and 3.5L 2004-2008 Acura TL and TL Type-S models, ES0004V2. I also want to get ATLP High-Flow Metallic Catalyst, for all 3.2L and 3.5L 2004-2008 Acura TL and TL Type-S models, ES0003HF. So will they work together? And how easy is it to install?
Thx
Oh btw---
04 TL 5AT WDP
Thx
Oh btw---
04 TL 5AT WDP
#663
94 DC4 RS LSV/Turbo
sorry, it'll need a spacer
Thx
Oh btw---
04 TL 5AT WDP
Thx
Oh btw---
04 TL 5AT WDP
#666
Year: 05
Trim: base
Color: ---
Example
Year: 2007
Trim: TYPE S
Color: Black
I'd like to know if i take the 07-08 mirrors with the turn signal insatlled in them i could fit them on my 05 acura tl . if so do i have to do any modifications ...Love u guys love this sirte
Year: 05
Trim: base
Color: ---
Example
Year: 2007
Trim: TYPE S
Color: Black
#667
94 DC4 RS LSV/Turbo
this is my fav one
Year: 05
Trim: base
Color: ---
Example
Year: 2007
Trim: TYPE S
Color: Black
Year: 05
Trim: base
Color: ---
Example
Year: 2007
Trim: TYPE S
Color: Black
#668
#669
#674
Year: 04
Trim: base 5AT
Color: Anthracite Metallic
I'm new to the forum. I'm looking for a new set of wheels to go with my car. Will the following set up fit?
5 x 114.3
Trim: base 5AT
5 x 114.3
FRONT WHEEL SIZE : 19 X 8.0 ET38MM
REAR WHEEL SIZE: 19 X 9.0 ET37MM
FRONT TIRE SIZE: 235/35R19
REAR TIRE SIZE: 265/30R19
#676
94 DC4 RS LSV/Turbo
Year: 04
Trim: base 5AT
5 x 114.3
Trim: base 5AT
5 x 114.3
your rear tire will be flush with the quarter panel, you may want to get just your rear fenders rolled
#677
Dear Guru
2005
New to Me
Manual
White
Car is not and will not be lowered
Current Set up: 18x7.5 et27 front
18x7.5 et37 rear
.....quite Doctored on by previous owner
Running 245/40/18 all around
I would like to put on:
1.) Advanti Racing A4 Kudos, 18x8 et40...have been told by every seller that these will fit over the front brakes.
or:
2.) MSR type 045 18x8 et35
I will maintain 245/40/18 with either wheel.
Thank you for you advise, Fulcrum.
2005
New to Me
Manual
White
18x7.5 et37 rear
or:
#679
Dear Guru,
Any opinions on the wheels ??
The Advanti look great in black and seem to be quality - 24lbs in 18 X 8 with a load rating of 1,700lbs.
MSR 045 are supposedly made in USA.
Thanks again, Fulcrum
