New style switchbacks!!!
Old Feb 5, 2008 | 05:33 PM
  #41
sunny201's Avatar
A J35A8 EG civic is in
<embed width="448" height="361" type="application/x-shockwave-flash" wmode="transparent" src="http://i158.photobucket.com/player.swf?file=http://vid158.photobucket.com/albums/t88/talwar201/switchback%20leds/CIMG4360.flv">
There it is.. it took a little while to upload
Old Feb 5, 2008 | 05:42 PM
  #42
sunny201's Avatar
ahh that kinda didnt work... http://s158.photobucket.com/albums/t...t=CIMG4360.flv that should link you to it
  #43
enigmaos's Avatar
Too Fast TOO FURIOUS
nice vid!
Old Feb 8, 2008 | 05:37 PM
  #44
rockyfeller's Avatar
King of NYC
thanks for the vid.
as me said they fix dem color......me likes.........hmph.
Old Feb 8, 2008 | 06:04 PM
  #45
RedHOT's Avatar
2012 TL SH-AWD Advance
Confused... Just got my new switchbacks 7443 but when I took the bulb out my car has 1157's... Hmm??? Did they change the bulb in the 07?
Old Feb 8, 2008 | 06:11 PM
  #46
RedHOT's Avatar
answered my own question by searching they are 1157's... any reason why i couldn't pick up a t20 socket adapter from the 2004-2006's?
Old Feb 11, 2008 | 10:32 AM
  #47
qtrung909's Avatar
where can i get the bulbs at?
Old Feb 11, 2008 | 10:50 AM
  #48
timmahh's Avatar
it's me, Alan Rickman.
did you have to use a resistor for these?
Old Feb 11, 2008 | 11:03 AM
  #49
RedHOT's Avatar
Check these threads out:
https://acurazine.com/forums/car-parts-sale-361/comptech-exhaust-used-headers-new-nex-used-173947/
https://acurazine.com/forums/car-parts-sale-361/fs-2002-tl-p-rims-tires-173959/
Old Feb 11, 2008 | 11:04 AM
  #50
RedHOT's Avatar
Check the first post of this thread add .com to the end of the name.
Old Feb 11, 2008 | 11:32 AM
  #51
King of NYC
Eh? 1157s??? Apparently they did change them huh? If I had known I would have told you, sorry. The 04-06s use 7443s for sure.
Acura has a habit of making small stupid subtle changes like that on a facelift. I wonder why they would do that, I'd imagine it would cost more for them to change the design. Maybe because 1157 bulbs are much more popular, but they should have done those bulbs from the get-go.
There are so many little things that shouldn't matter that they made non-interchangable on the 07+ cars. (Like the way the Type-S rear trim is 1mm too big for the pre-06s.....WHY??)
Old Feb 11, 2008 | 11:40 AM
  #52
RedHOT's Avatar
My 2 cents to why they changed the bulb... Since my headlights are 3/4 cleared from the factory you can see the bulb... The 1157 is a nice round bulb where the 7443 is longer and not round. I really think its that simple, but at the same time who really knows.
Old Feb 11, 2008 | 11:44 AM
  #53
enigmaos's Avatar
wait, sunny201 has 7443 LEDs up front in his 07 TL.
Old Feb 11, 2008 | 11:48 AM
  #54
RedHOT's Avatar
Bet its not a Type S?
Old Feb 11, 2008 | 11:50 AM
  #55
enigmaos's Avatar
it's base.
Old Feb 11, 2008 | 11:53 AM
  #56
sunny201's Avatar
it's base.
Yes it is
Old Feb 11, 2008 | 11:56 AM
  #57
sunny201's Avatar
Did you put that in?... I put in the typeS rear trim and it was just a bit too big... and it has 3 squares instead of 2... so i just did a little customizing and got it to fit... how did you get it to fit?
Old Feb 11, 2008 | 11:28 PM
  #58
King of NYC
ahhh. good point. that's exactly what it must be. 1157 is more globular and 7443 is oblong a bit.
Sunny, I bought the Type-S trim and trimmed 1mm too much on both sides and used double-sided tape. I was unhappy with it. Then I landed 2 scratches on it and burned it with a dremel bit during my backup cam install. Not too noticable but I chucked it. Bought another one and had a hard time taking the old one off. The double-sided tape was strong stuff. This time I decided not to trim the new piece and I wedged in there trying to rely on the double-sided tape. The pressure from the bowing of the piece took over and it came loose twice already. It's still bowing, it's not going anywhere for now, it's been like that for 5 months. I have to fix it when the weather gets better. I guess I'll have to trim...
Old Feb 12, 2008 | 12:06 AM
  #59
sunny201's Avatar
I put two screws from the bottom towards the top so it doesnt stick out.. Its a ghetto job but you cant see the screws unless your looking for it. Maybe ill take a pic. I didnt use any tape or anything.
A question for any who have these already, is it just both of my bulbs or do they have to heat up for a bit (like stay on for at least a minute or so) for them to actually start flashing amber and staying white. I started the car and turned on the turn signal to show my brother and the first flash was amber, then it just kept flashing white on and off.. Then about a minute later it worked perfectly(flashing amber but staying lit white).
Old Feb 12, 2008 | 02:12 PM
  #60
enigmaos's Avatar
^I bet the freezing temps caused them to do that, but I am not certain. anybody with new switchbacks can confirm?
Old Feb 12, 2008 | 02:15 PM
  #61
RedHOT's Avatar
soonish mine are on the way.
Old Feb 12, 2008 | 07:03 PM
  #62
King of NYC
you used screws? why? it should be just plug-n-play??
your switchbacks take a minute to work??? EH? No they shouldn't....Mine work immediately, everytime on cue perfectly......Somehow maybe there is some wiring that is wrong, a loose connection or the contacts of the bulb and receptacle are not in the correct position. The 7443 has a pair of contacts for the high/low setting of the bulb that should correspond to whether the white or amber should be lit. Lastly it could be temperature but I doubt it. I don't have those problems. If it persists, after troubleshooting, send them back.
Old Feb 12, 2008 | 08:41 PM
  #63
sunny201's Avatar
i was talkin about the rear lisence plate trim from the TL-S
it cant be just the bulb or the connection because both of them do it.. if I leave the park lights on for about a minute and turn on the signal they work perfectly, its only when i first start them up.. kind of weird.. Im guessing its the cold, ill find out as it should be warming up pretty soon. If not then I guess Ill have to contact autolumination
Old Feb 13, 2008 | 01:23 AM
  #64
King of NYC
OK but you tapped the screws into metal or plastic on the other side? Into metal could mean rust....Into plastic could mean cracking under stress. As long as it works it might not be a bad idea.
hmmmm yeah weird, keep an eye on it.
Old Feb 14, 2008 | 05:17 PM
  #65
RedHOT's Avatar
Got my switchbacks today... Its about 37f here and it took them about 30 seconds to start blinking white to amber.
Old Feb 14, 2008 | 05:52 PM
  #66
ABP_04TL's Avatar
6-SPEED LOVER
Old Feb 16, 2008 | 01:37 AM
  #67
ballerjai's Avatar
Make Nice, Not Rice
dang you guys are confusing me sorry. I have a 07 TL-S, what number do i need for the signal lights to have switchbacks?
Old Feb 16, 2008 | 01:38 AM
  #68
RedHOT's Avatar
1157's in the front... 7443's in the back... holds true only for the Type S
Old Feb 17, 2008 | 01:37 AM
  #69
ballerjai's Avatar
Make Nice, Not Rice
thank you redhot =D
Old Feb 19, 2008 | 06:40 AM
  #70
King of NYC
???? I don't get it. They shouldn't be doing that. If your car is garaged try operating them after the car has been there for awhile. My garage is about 45 degrees, if it is temperature related it should work then.
Make sure you complain about this to autolumination because my ol skool HF-LED switchbacks don't do that and neither does bforbrian's. If they take 30 sec. it defeats the whole purpose! It HAS to come on instantly.
Old Feb 19, 2008 | 08:09 AM
  #71
stillhere153's Avatar
94 DC4 RS LSV/Turbo
I think they mean when they initially start the car rocky
Old Feb 28, 2008 | 04:14 AM
  #72
ballerjai's Avatar
Make Nice, Not Rice
the website offers 20 LED and 30 LED switchbacks for 1157. the 30 LED is called the "30 LED SMT" What does SMT mean? Which do you guys recommend, and do both of them fix the stock housing (plug and play)
Old Feb 28, 2008 | 10:49 AM
  #73
King of NYC
SMTs are surface mount technology type of LEDs. They are among some of the newest types of LEDs and are called so because they are soldered directly to the surface of the circuit board. They are smaller (comparatively to other LEDs of similar specs) and lower profile than past designs so can be used in wider types of applications.
The 30 LED model is the "new" model we are talking about. The 20 LED model is the older one that needs modding to the housing to enlarge the bulb opening because it uses the larger older style HF (high-flux) LEDs.
Old Mar 3, 2008 | 05:47 PM
  #74
Fulani has a TL's Avatar
yo RedHOT you got pics of the lights yet, or am I gonna have to wait for RBP_04TL to clear his lights?!
Old Mar 14, 2008 | 01:20 PM
  #75
King of NYC
any update about the "delay" flashing with the new switchbacks? Is it still doing that guys? Has autolumination given you an answer?
Old Mar 14, 2008 | 06:10 PM
  #76
ABP_04TL's Avatar
6-SPEED LOVER
havent had a chance 2 get mines installed and cleared yet
Old Mar 17, 2008 | 03:57 PM
  #77
dashiz_07TL's Avatar
-Shiv- 07TL nav
were can u get the switchbacks from any link??
Jul 16, 2017 07:33 AM
detailersdomain
Wash & Wax
Oct 9, 2015 10:13 PM
baowheezy
Sep 22, 2015 09:03 PM
njresendez
3G TL Photograph Gallery
Sep 21, 2015 06:32 PM
