New CREE DTRL bulbs available
#162
I will let you know when those Plasma LED comes out. Once I have in hand I will post pictures and test them out and give feedbacks
i have been planning to put up a thread on how i installed my DRL kit on my 08 type s...but i'm waiting for one for fix on my kit and then i can put up pics..might not be the quality of a true DIY but i can do my best to try to help someone out
oh and raymond keep me updated on the plasma SMD i would be interested to see how bright they are for the DRL (2x brighter than CREE sounds pretty intense!)
#163
2007 6SMT Type-S
Just got the JLC CREE DRL kit. It looks pretty straight forward (surprised it doesn't require direct power from the battery) but mine came with two modules (see picture). I paid for a lifetime replacement so is the 2nd module a back up or is the 2nd one supposed to plug into the other side of the factory wire harness?
The components feel really cheap and I can feel/hear things rattling around inside the modules. Let's home they work.
Uploaded with ImageShack.us
#164
the complicated module goes on the passenger side and the long wire has to connect from the passenger side all the way to the driver side DRL light. let me know if you have questions. i have one issue with my passenger side module and a new kit is currently in the mail, i can update it once it is all done.
#165
07-08 only comes with the Module. 09-UP 4G comes with Module and relay harness since it needs to bypass the error message on the dash and the computer more complicated on the 4G TL
#167
2007 6SMT Type-S
Gottcha!
PROBLEM! So my DRL stopped working months ago, figured one of the blubs when bad and I was planning on upgrading to LED's eventually (which I'm now trying to do). The kit didn't work. Bought some stock halogens and put them in to trouble shoot. New bulbs=still no power. What should I try next?
The factory connector is cracked pretty good and it looks like someone tried to reconnect it at one point or another. So...I'm going to go buy a new stock connector and replace. If that doesn't work, what next?
#169
2007 6SMT Type-S
Okay, so I just replaced the 9005 connector and new halogens. No power, DRL still stays on, on the dash. Checked the fuse under the steering wheel labeled DRL, it's not blown. What next?
#170
Rev High; Drive Happy
If your fuse isn't blown and the lights aren't coming on you might have bad wiring or a bad short.
#173
2007 6SMT Type-S
Replaced relay which is next to the fan control, located on passenger side next to radiator.
Last question, where are you guys grounding your hanress?
#175
2007 6SMT Type-S
FUCK THESE LIGHTS! Cheap, cheap, cheap! Sometimes they work, sometimes they don't! Sometimes they'd even stay on with the key removed! I'll say it again, FUCK'EM! Sending this cheap ass China shit back and going with ugly but reliable halogens! Buyer beware!
#177
2007 6SMT Type-S
Nah, I appreciate the help and suggestions I have gotten here but the hell with this crap. This is why I like to stick with OME products. I'm sending the garbage back. It felt cheap when I got it. I kept getting wires pulling out of the connectors (and I was being cautious with them), I can only imagine how many times I'd have to pull them apart, fixing them down the road. At least my DRL work so I can pass inspection. Good luck to those who bought them.
#179
once i used one of the good grounds, the lights worked just fine. PM me if you have any specific questions, JLC has good customer service any time I had issues Jack would answer my emails or send me youtube videos to help out.
bad ground
passenger side ground and mount
driver side
comparison using 68 LED SMD
#180
2007 6SMT Type-S
I think I had a good ground, I sanded the frame down to the metal. It WAS working, but it actually had power while the key was off...which is obviously not a good thing if you want to start your car later. So I disconnected it and checked the wires just for the hell of it. Touched it to the battery's Neg terminal and they lit up. Reconnected everything and they wouldn't work (yes, I made sure the parking brake was off and I threw it into reverse and 1st, let the clutch out just to make sure. I like the way these lights work and I've built my own HID wire harness so install was super easy. Just don't know why they stayed on w/o the key in, and why they don't work at all now.
#181
Desert Life Sucks!!
Bad relay?? putting power in off pos. and not the on position?? you did say you swapped them.
And glad I went rogue and got my own reverse lights and lic plate lights and not with the group buy. Working towards a quad projector setup so hopefully eliminate DRL all-together.
#182
2007 6SMT Type-S
I should note that the switchbacks work perfectly until the running lights have been on for at least a couple minutes. Then they go haywire.
stemslayit (01-17-2012)
#183
Desert Life Sucks!!
Mine blinked fine then acted like type 1's and then went back to a normal type 2.
As far as my switchbacks. It was really weird but they work flawlessly now so not really sure as I only soldered a .12 ohm resistor.
But as far as what you are having I would have to check it out. Sounds pretty gay though. I agree though that a bad ground will cause all sorts of things to act funky and not work correctly.
Even a loose ground let alone a not very good ground.
i do say good luck to you and post anything you find out maybe one of us can help.
#184
Mile High
I bought the bulbs and the harness when they first came out. I could never get the harness to work properly (it had issues when they first made them), and so I just decided to try it without the harness.
Long story short, I have been running the V-LED bulbs with no harness or module and NO DRL CODE for over a year now, and I love them.
V-LEDs Switchbacks + DRLs looks REALLY nice when the lighting is dim.
#185
So everyone has had ask these problems, and all you're doing is plugging the bulbs in directly as if they were the oem bulbs? Very interesting. And they certainly look bright to me, half power or not.
#186
Mile High
The guys at V-LEDs told me they are running at half power as well, but they are the same brightness as the switchbacks, and plenty bright for me so I dunno
#187
All About Trance
That's good to know, DigitalEmpire22. I'm leaning more towards the V-LED LED DRLs more than the one from iJDMtoys. Even better that it doesn't require a harness.
#188
go with JLClightings.com for the DRL LED kit, they have sold over 50 kits with no codes and full power, you have a much better chance of success than going with other companies that have less than a 50/50 chance of no code/full power (at least from what i've heard from members on AZ)
#189
All About Trance
I'll pass on JLC based off of my previous experience with them.
#190
Everyone says you need the resistor kit or a module to run the V-LED bulbs without throwing a DRL code, but.....
#191
Mile High
I have the 6k on both the switchbacks and DRLs. I believe I am using the V2 switchbacks, any reason you want the Type 1s?
My only gripe with the switchbacks is some of the LEDs are starting to flicker on and off every now and again. (its been about a year and a month since they were installed)
#192
Mile High
Here are a few more pics I found in my photo bucket account of the V-LEDs DRLs/Switchbacks at different angles and times of day.
Just for good measure you know
#193
Very nice
#194
I know you said you are using the V-LED brand, but are is this what you are using?
http://www.jlclightings.com/1157-752...-p/sku_025.htm
ripit
09-26-2015 06:19 PM
