need help with wiring!
Old Aug 20, 2009 | 06:15 PM
eenk's Avatar
sorry if this isnt the right place to post this move it if you have too.
ok so i tried wiring my fogs again and no luck i would take a pic of the harness but im about to run to hospital because my little sister is about to have her baby.
but i got a ebay accord fogkit, the harness i have has 2 relays, one relay has red/red,black/blue,blue,red. 2nd relay has red,yellow,blue,black/blue. then theres the 2 plugs that plugs into the headlights and 2 blue attached to a gold ring which i assume is for grounding.
im trying to hook it up without the switch. so far ive been trying.
i take yellow and red wire from one of the relay and tap it into the positive lead of the battery, and i ground the blue. i take the red from the other relay and tap it into the fuse with headlight or foglight and ground the blue but i get nothing.
is my decription baddd??? lol ill take pics of my harness later, from other threads i read people have a slight different colors with their ebay harness.
any help will be appeciated, i wonder if i have bad ground?
Old Aug 24, 2009 | 05:37 PM
draztik's Avatar
I'm trying to do the same thing as you. I'm having problems trying to wire my ebay fogs (it has 2 relays as well). Can anyone give lead us in the right direction? THX!
Old Aug 24, 2009 | 08:54 PM
dwb993's Avatar
You can try these threads:
https://acurazine.com/forums/3g-tl-photograph-gallery-96/help-suggestion-needed-07-05-type-s-front-bumper-swap-620708/
https://acurazine.com/forums/3g-tl-2004-2008-93/grate-grin-stock-05-tl-610472/
But I have not seen any threads about ebay kits with more than one relay. Mine only came with one.
Acura604
20
Aug 5, 2017 12:55 AM
ITSJESTER
4G TL Photograph Gallery
Oct 13, 2015 12:53 PM
MilanoRedDashR
Oct 8, 2015 10:30 AM
SUPRMN84
Oct 7, 2015 09:46 PM
27trains
4G TL Problems & Fixes
Sep 30, 2015 09:44 AM
