Need help finding this bolt
Old Aug 8, 2010 | 02:47 PM
libert69's Avatar
18psi
Circled in the picture is the bolt that connects the oil pan to the transmission. I cant find this bolt on acuraoemparts.com
Need some help please
Old Aug 8, 2010 | 05:29 PM
InFaMouSLink's Avatar
Chapter Leader (NY/NJ)
call them and find the specs for that sucker.
Old Aug 8, 2010 | 06:37 PM
Tehvine's Avatar
6spd FTW
I believe there are two of them, correct? Service manual says 12x1.25mm thread. It does not list the length unfortunately.
Old Aug 8, 2010 | 07:50 PM
libert69's Avatar
18psi
Im going to have to call the dealer bc I cant find them anywhere. Yes there are 2 of them.
If you look in the service manual in the section for the oil pan, it says these 2 bolts are 10x1.25mm but no length
If you check the service manual in the section for removing the transmission, it says these 2 bolts are 12x1.25mm but no length.
WTF
Old Aug 8, 2010 | 09:38 PM
i looked over the service manual. it says 10X 1.25. it appears bolt 28 is the same and the one your looking for.
Old Aug 8, 2010 | 10:09 PM
libert69's Avatar
18psi
^check the manual on page 7-28
then check 14-218
those 2 procedures are referring to the same bolts correct?
are you saying bolt 28 from the diagram above? thats listed as (6X50) though
Old Aug 8, 2010 | 10:43 PM
libert69's Avatar
18psi
heres a number 10 bolt inside the hole. Its clearly not big enough for the hole. A number 12 bolt would definitely fit better. Still searching for the length. Anyone want to pull one off there car and measure for me?
Old Aug 8, 2010 | 11:28 PM
see if that "6X50" bolt (#28) that you should have already fits.
Old Aug 8, 2010 | 11:34 PM
Inaccurate's Avatar
Part #17 ? This is the closest thing that I can find.
Look in the sub-component section called "ALTERNATOR BRACKET" (click here)
Regarding the diameter fitting in the hole. The pic with your finger looks correct. I think a 12mm would be too snug. It in normal for Honda to have large holes. There are probably pilot pins in the case used for proper alignment. The bolts normally are not meant to provide alignment.
Old Aug 9, 2010 | 01:22 AM
libert69's Avatar
18psi
Inaccurate to the rescue. Thank you.
Part number 17 is a 10x55. But part number 19 is a 12x80....and the service manual says in the oil pan section that it is a size 10. But the trans removal section says a size 12 lol
I guess ill be buying 4 bolts then
Yikes
May 3, 2021 04:29 PM
cycdaniel
Dec 17, 2019 10:58 AM
Rapture
Oct 4, 2015 12:05 AM
DUECE_DXJ
Sep 24, 2015 04:54 PM
darksky
Sep 5, 2015 03:11 AM
