Motor Trend Long Term Test 04 TL-merged with thread started 10/8/05
Old 09-10-2005, 10:20 PM
Tennisjon2002's Avatar
Got my new motor trend in the mail today(october), it has a long term test of the 04 TL. It seemed liek they liked it but they touched on a few of the issues people are having here (fading dash, new brakes and wraped rotors were needed and crappy tires.) They thought the dash was due to bad cleaning products at a full service car wash but I would have to say they are wrong due to so many people having problems here. Just thought it was an intresting read and maybe Me or someone will post up the article if there is intrest.
Old 09-12-2005, 03:43 PM
scrb09's Avatar
can you scan up and post the article ? interested to read the review...
Old 09-12-2005, 03:53 PM
Once more into the breach
peacefrog's Avatar
interested in article, post it please
Old 09-12-2005, 05:37 PM
Tecworld's Avatar
I had warped/glazed rotors and brake shudder at 19k miles. I read about this before so I knew it was an issue with some new TLs. The guy at Acura actually tried making me pay for this at first, so I told him I also have an Accord which didn't exhibit brake shudder until 95k miles and 3 rotor machine jobs. He called his manager and approved it as warrantee work under "goodwill". If anyone feels brake shudder within the first brake job, DO NOT ALLOW THEM TO MAKE YOU PAY FOR THE WORK.
That's all.
Old 09-12-2005, 05:55 PM
Been there
04TL5ATNAV's Avatar
Same here, my rotors warped around 7k miles and I complained for two oil change appointments. On the 3rd, we argued and argued and I finally got them to turn the rotors as a "goodwill" gesture which is B.S.
Old 09-12-2005, 06:02 PM
TL_BLUE's Avatar
what is brake shudder?? and yes, please post that article, thanks!
Old 09-12-2005, 07:31 PM
rescueswimmer's Avatar
Brake shudder is another term for pulsation. When you apply the brakes you can feel the steering wheel shake and feel the brake pedal pulsate. Hope this helps
Old 09-12-2005, 07:53 PM
Administrator
Ron A's Avatar
Received 1,003 Likes on 573 Posts
The administrators do not want complete articles posted here because of possible copyright infringements.
Selected portions may be quoted, as long as they are kept to a minimum, but not the complete article.
If you have a link to an online source for the article, you may post the link.
Old 09-12-2005, 11:42 PM
bulacura's Avatar
dash fading?? i believe that armorall messes up the dash, because it contains silicone. my old car had a gray interior, after a year of armorall use my gray interior turned to brownish color. people actually thought i had a tan interior. therefor i refuse to clean with armorall, just with a wet rag.
Old 09-13-2005, 06:08 AM
mickey3c's Avatar
Well the 04 was not one of the used cars with a better than average reliability record. It did not make that list in consumer reports. The 03 did make it.
Old 09-13-2005, 06:34 AM
WdnUlik2no's Avatar
yeah I stay away from amorall.
Old 09-13-2005, 10:56 AM
Community Architect
robb m.
astro's Avatar
Tennis: you may scan and post the article, just include the magazines logos etc.
Old 09-13-2005, 12:32 PM
massr1's Avatar
just go to motortrend.com, the article is under road tests - long term update
Old 09-13-2005, 02:20 PM
I can't find the whole review online but I will scan it and post it when i get home
Old 09-13-2005, 06:04 PM
Here it is:
Just send me a pm with your email if u would like it in a better quality pdf for use with a dealer or something
Old 09-13-2005, 08:25 PM
DMZ
Head a da Family
DMZ's Avatar
Make sure they don't over tighten the lug nuts. They should be 80 ft-lbs. Overtightened lug nuts are one of the chief causes of warped rotors on Acuras and Hondas.
Old 09-13-2005, 08:30 PM
If you tighten them by hand can you "overtighten" them or does this just apply when using the electric thing(don't know what it is called)
Old 09-13-2005, 08:52 PM
Team NightHawk VP
cliff's Avatar
u can over torque them with your hands too, but not likely, unless you got really big arms
Old 09-14-2005, 05:33 AM
WDP Director of R & D
KJSmitty's Avatar
Small arms and a lot of leverage = over-torquing
Basically, if you're using an 8-10 inch ratchet 80lbs takes some force. If you have a 20+ inch breaker bar, 80lbs is quite easily achieved/exceeded...
Old 09-18-2005, 08:14 PM
neuronbob's Avatar
Received 4,613 Likes on 2,193 Posts
Thanks for the scans, jon. I plan to post my two-year TL impressions in a couple of weeks. I can't believe it's been that long already.
A preview: I can still drive it like I stole it. 'nuff said.
Old 09-18-2005, 08:33 PM
Cold Racketeer
tzakiel's Avatar
Love how they couldn't end it without an advertisement for BMW at the bottom.
Old 09-18-2005, 08:43 PM
mickey3c's Avatar
I am sure that the brake problem as well as others is caused by cheaper materials. The sedan is the lower priced of all that were compared and while they might not like the G interior as well, the TL is more cheaply constructed and this has shown across the brand since the 2g debuted. The problem I have is even if thye give you new brakes at 15k you still have the same problem later and have to look to aftermarket parts
I am sure that over torqueing the bolts might cause some issue now and then but why does acura seem to have this problem much more so than any other.
Old 10-08-2005, 10:17 AM
Bobz
Bobzmcishl's Avatar
Motor Trend Long Term Test of 2004 TL
I got around to reading the Motor Trend New Car issue article on their long term test of the Acura TL. Overall they liked the car very much and basically said if it were rwd, it would be hands down the best car in its segment. However they found several flaws which have been reported ad nauseum on this web-site:
1. Torque steer (which I understand has been corrected on 06 model). Motor Trend wondered how Acura engineers failed to address that problem before car was rolled out to public.
2. Low profile tires which on the AT version of car are inadequate (as we all know), and furthermore they cause the rims to scratch too easily. The reviewer noted that he had left a lot of silver paint on curbs all over L.A.
3. Discoloration on the top of dash which they thought could have been caused by sun but more likely, by automatic car wash people who use too strong a solvent to clean interior of vehicle. I have also noticed this problem on my 04, and I do go to a automatic car wash rather than clean it myself. I haven't seen any comments about this problem from others on this site.
Motor Trend loved the audio system and said it was best on market. They also loved interior in general. I thought the article was interesting in that they pointed out all of the strengths and weaknesses of the TL which have been reported on here, except for the top of the dash discoloration. I am going to talk to my Acura dealer about this problem next time I bring the car in for service.
Old 10-08-2005, 10:21 AM
invincible569's Avatar
Just shows you those car magazines arent biased. Great post bro.
Old 10-08-2005, 10:47 AM
2005TL(6MT)
clsdave's Avatar
May be not in this case as the test is very accurate.
There are other magazines that are very biased in their reviews/tests. IE: Car And Driver can't seem to let BMW place anything less then first in a comparison. And sometimes make unfair comparisons.
Old 10-08-2005, 10:48 AM
Regions Leader
trancemission's Avatar
niec post Bob. I agree with that torque steer, man you gotta hang on..
Old 10-08-2005, 10:58 AM
good info though
https://acurazine.com/forums/car-parts-sale-361/boston-pro-6-5s-nib-two-pair-sale-122638/
Old 10-08-2005, 01:41 PM
mickey3c's Avatar
Motor Trend loved the audio system and said it was best on market. They also loved interior in general. I thought the article was interesting in that they pointed out all of the strengths and weaknesses of the TL which have been reported on here, except for the top of the dash discoloration. I am going to talk to my Acura dealer about this problem next time I bring the car in for service.[/QUOTE]
Most if not all FWD can experience some torque steer. My first front driver had it 20 years back. As for totally eliminating that problem, it could take some performance away from the car. The tires help in keeping the car planted to the road surface.
As for the rim scratching too easily... The 2 g design rims protruded too much but was corrected in later 2g models. But... the lower profile tires are not higher than the curbs, so if you like to use the touch method to pull against a curb you are going to get damage. You can get tires with reinforced sidewalls which help protect against side wall damage, but you are going to have scratched rims with performance tires if you do not know how to drive. Lower profile rims to not cause scratches...PEOPLE DO...
Old 10-08-2005, 06:45 PM
KJSmitty's Avatar
Due to the fact that the power goes through the front wheels and the front wheels "steer' the vehicle, getting "completely" rid of torque steer would be very hard (if not impossible) on FWD vehicles. You may very well eliminate all of the mechanical causes: even length axles, perfect torque split differential, adaptive steering dampening, etc. etc., but like someone mentioned above, road variations will near always cause FWD cars to "vector" a little on hard accelerations.. Thats the variable that engineers can't remove.
Someday we will probably see/drive "steer by wire" vehicles with algorithms that do a great job of replicating road feel yet at the same time remove all "steering wheel" torque feel. Then it would be like a RWD... You may get a vehicular motion from the torque but the driver would be reacting to the car without the steering wheel being pulled one direction or another.
Bottom line, for those of us that have owned many make/models of FWD vehicles, I find Honda's to be one of the best in regards to managing torque steer.
Cheers
Old 10-08-2005, 07:06 PM
Brettg's Avatar
All other brands get warped rotors.
When I was on the Jaguar list, everyone had warped rotors.
On the Passat list, everyone had warped rotors.
My wife used to have a new Taurus that warped its rotors twice in its first year.
On the other hand, I have NEVER had warped rotors on my cars.
I do the brake work, and dont let anyone use an air impact wrench on my lug nuts. I use a tourqe wrench.
Care during the brake work prevents warped rotors, using
quality parts, cleaning the mating surfaces, using high temp grease
on the rotor flanges (aids in heat transfer) and on the back of the pads
(eliminates noise).
Have your brakes done at any shop and they just slap new parts on rusty
hubs, and do up the lug nuts to 200 ft pounds with an air impact wrench.
For many cars (even Jaguars) quality rotors like brembo or ate cost
around $30.00 each if you know where to shop.
It does not pay to do anything but replace them with the pads.
On my 2003 passat GLX (german parts are usualy expensive),
www.getcoolparts.com had rotors for under $30.00 each, no tax
and free shipping.
Brett
Old 10-08-2005, 10:06 PM
mickey3c's Avatar
Brett
Not so... I have been driving a lot of cars over 30 years and the only car that ever got warped rotors was after they were turned. They had to be replaced every brake job (50K). You been driving crap is all. My 2G CL S type had original brakes when I traded it at 83,000 miles. No warping at all..
Maybe you and the wife are very hard on your cars.. As for the ford... that's a Fix Or Repair Daily automobile...
thing is the 3Gs have more brake issues than the 2Gs had...
Stop believing that it is normal to get warped rotors... IT ISN'T Crap for quality is what it is or poor assembly process...
Old 10-08-2005, 11:40 PM
04 Anthracite,6spd,No Nav
Nello1's Avatar
My dash is totally faded, I mean bad. Pretty much turning a powder white. I do not garage my car so it does get some sun. Lucky me it all started at about 4 months after purchase. This car has been detailed only once; buy the dealer when they added the paint sealant crap. Shortly after is when I noticed the fade. Acura has tried and tried to fix it but they have had no luck. They originally told me they would need to replace my entire dash. When I told them if that is true they would need to buy back my car and kick down a new car without the problem. I don't need my airbags and everything else torn up in my brand new 35k car. Of course they said they had a fix for it afterwards...not. They have unsuccessfully tried 5 or 6 times now by 2 different dealers. It has just gotten worse guys, if you have a problem get it documented ASAP.
Old 10-08-2005, 11:42 PM
rarely registered user
The 06 reportedly has new engine management software to limit the torque steer. It will be interesting to see what people say about it as more 06 drivers filter to this forum.
I don't think we'll ever see anything rear drive from Acura, so the magazines ought to get over it.
Old 10-09-2005, 05:06 PM
Black
lindros2's Avatar
I have "only" 17,000 miles in 2 years, but did face warped rotors on my TL (replaced by dealer). Regardless of who does the brake work, there is either a flaw or issue with cheap parts on the TL. Hell, I didn't even *need* brake work - mine was blamed on "washing the car with hot brakes" and "leaving the car in the rain" (note - my car is garaged at home and office).
It's not just in the brake department, but this is definitely a weak area.
-josh
Old 10-09-2005, 05:52 PM
Aaaarrrggghhhh!
Scribesoft's Avatar
.. As for the ford... that's a Fix Or Repair Daily automobile.....
I always thought they were First On Race Day?
\Personal Dream Muscle Car "project" is a '69 Mach 1 428 Cobra Jet (R code).. If I can just get my damn wife to agree with me. Her usual response =
\\Don't tell her I called her my "damn wife"
\\\Running now.......
Old 10-10-2005, 09:29 AM
Bobz
Bobzmcishl's Avatar
Thanks for the verification that this seems to be a common problem. I also keep my car out in the sun a lot, but know way would sun have caused the dash turning that milky white color. Obviously this problem will reduce value of car at resale time, & it is a constant irritation on an otherwise nice looking car.
Old 10-10-2005, 09:35 AM
Bobz
Bobzmcishl's Avatar
Thumbs up
I sympathize with you. I have a 66 Mustang Convertible which is my favorite car, Acura TL included. I like my TL but I love my Mustang. New cars just don't engender the same feeling - possibly because most of them are so generic looking. The longer you postpone buying your dream car the more it will cost, especially any of the highly desirable muscle cars like your dream car. My wife doesn't complain anymore about my car, since she know how much it has appreciated in value the last five years. It's worth more than my TL and Beemer. Sometimes it is better to ask forgiveness than permission.
Old 10-10-2005, 09:58 AM
n1976jmk's Avatar
I had picked up the 06' TL 5AT last week but, from what i hear the tourqe steer thing has only been changed on the 6MT
Old 10-10-2005, 11:19 AM
Spinnin them beats
Acuraluvr's Avatar
bigger easier reading
Old 10-10-2005, 11:20 AM
Spinnin them beats
Acuraluvr's Avatar
but 0-60 in 6.9??? WTF
and wonder if they will change the HP rating for their big 'every car tested' book thing in the back of the mag.
Quick Reply: Motor Trend Long Term Test 04 TL-merged with thread started 10/8/05
