manual or auto
![Question](https://acurazine.com/forums/images/icons/icon5.gif)
hello guys, I'm new here. I've been searching to buy an TL for awhile now. I always to buy a manual, but its seem so hard to find a TL manual transmission. so I'm asking, is it really different between auto TL and manual TL? and I'm from cali btw.
Registered Member
Go for the manual if you can find one.
I need a car in
1 Post
i guess you'll be one of my competitor to buy a tl in california! -_-. im still shopping around for a car
both of them have some problems which are different. i read some up on the problem and fixes section. i.e: auto transmission sensor getting dirty, manual 3rd gear having a problem. its minor but its something you can take into consideration. but as far as i know the auto isnt as bad as the old honda tranny from what i had read so far.....hopefully better then my old prelude tranny where they seem to failed just like the accord
I have about 20days to find it, I just got back from japan from my previous work station. I plan to drive them up to san diego where i'll be stationed at. worst case, I will keep hunting for the manual when i get to SD.
6MT all day.... although if you will be in heavy traffic pretty often then you may want to get an automatic. This will be your determining factor (it would be mine atleast). you are heading in the right direction even getting a TL IMO. Good Luck! U getting stationed at Miramar?
The manual also has better brakes, but they wear out quickly while the brakes on the automatic last forever so if maintenance costs are a concern I would get an automatic.
Registered Member
One of my next door neighbors has an '05 manual with 80,000 miles on his stock factory installed pads.
So do keep in mind that there are other factors involved here.
Not necessarily so. I replaced my OEM pads at around 15,000 miles, not because they needed it, but because I hated all of the black the dusting. I still have the stock pads and they are probably good for another 35,000 miles.
My 04 TL still hasn't had a brake job done (just a fluid flush), but at my last oil change they told me I should get it done next oil change.
Manual quite smooth in trafic
I agree that a manual transmission is not the best choice for heavy traffic cities but the 6MT 3rd gen TL is by far the smoothest manual car I ever drove in traffic.
With its "by wire" throttle, the TL is able to prevent low speed stall by "pushing" the engine, for example in 2nd or 3rd gear. It almost feels like an automatic transmission as you can slow down very much without depressing the clutch pedal and control your speed with the brakes. You can see it work by watching the RPMs. Also, the 6MT has an aditionnal engine rocking damper and I believe it may play an aditional role in slow traffic. Compared to all my previous cars, there's almost no "jerking" in slow traffic.
Add this to rev matching (upshift and downshift when you blip the throttle) and you have a very polyvalent car. Smooth if you feel this way, or a beast if you ask for it.
Hope this helps.
Carl
2004 6MT Anthracite Metalic - A-Spec suspension, body kit, wheels.
Hope this helps.
Carl
Registered Member
If that's true then that is not so bad. For some reason I had the impression that MT TLs needed the brake pads changed a lot more frequently, probably due to the large number of topics here about people with newer (07-08) TLs asking about changing their pads.
Just a guess, though.. you understand.
Registered Member
Hope this helps.
Carl
Hope this helps.
Carl
Incidentally, I would steer clear of rev-matching when upshifting unless you had to hold the shift for a moment, thereby disrupting your rhythm.
Did you know that the 6MT has software that deliberately reduces throttle response at very low speeds in first gear so that you don't get that "bucking" result when adding a some throttle. It's done for that and also as a safety feature so you don't suddenly contact the vehicle ahead of you.
As for rev-matching when upshifting, that's a nice feature when taking grand'ma to the drugstore.... very smooth transitions.
![Yawn](https://acurazine.com/forums/images/smilies/yawn.gif)
Cheers.
Carl
Registered Member
Thanks for the additional info SouthernBoy. I was not aware of the reduced throttle response at very low speed in first gear. So many things can be done now that the ECU has a grip on the throttle.
You're right saying you can't wait for it in normal and spirited driving. Wish the revs go down faster. Probably need a lighter flywheel for this.
Cheers.
Carl
Cheers.
Carl
BTW. Make sure you include a double clutch with your downshift rev-match to complete the process. Reduces synchro wear.
@locwind
Well, seriously, you're not going to be in SD, right? According to your post, you're more likely to commute to SD, with SoCal's traffic condition, go for a 07 TL-S (Auto)...
I now have a TL-AT, I wish I had a MT, but it is slim pickens here in South FL, no one gets rid of their MT down here. So I had to settle. Its been hard to adjust considering I was driving the '99 2.3CL MT for almost 10 yrs and I loved it......EXCEPT for the 11 months that I lived in The City of Angeles. Having an MT there during L.A. traffic was the worst experience in driving that I have had in my life. I'm planning to move back or move to The Bay Area (I couldn't imagine having a MT in the heart of Downtown SanFran), so that played a role in buying an AT TL. So...normally I would say MT, but in SoCal, i would give the AT a long look.
Really the traffic in and around San Diego is only bad for about 30 minutes in the morning and evening on some freeways, compared to OC and LA its nothing. Go for a manual if you can find one.
2008 335i e92 6MT
that's the hard part x_X now a days... not deciding whether you should get it, finding a good MT first is the trick. i have yet to see any base TL MT's for sale but a good amount of type-s MT's. but that's the more eastern region of the country.
Needs wheels
I say go for the 6MT...if you think you want it you need to get it. I looked for a while in ATL and eventually had mine shipped from Miami. I would not even consider an AT when I was looking.
if i could do it again i would def go with the manual i unfortunately thought the paddle shifter were really cool at first so got an auto ... don't make a mistake and get an auto
It's not even a question! 6mt... set, point, match. Heavy traffic? I wouldn't wanna use that as a reason NOT to get one. If you've driven a manual and even if you haven't, you'll find yourself getting used to driving in ALL types of adverse conditions (traffic, hills, snow,etc). But once you get 'er on that open road, watch out! Game over (in more ways than one if highway patrols on your ass, but I digress) I've heard quite a few regrets with going Auto and 'wishing' they had opted for the 6mt (previous posts included?
). I can't say I've heard the too many regrets going the OTHER way, though. I went for 6mt and didn't even look back. But then again, you have to consider other personal factors (who else will be driving the car? you going to mod it? Do you really really really hate heavy traffic with 6mt?)
![Dunno](https://acurazine.com/forums/images/smilies/dunno.gif)
LIST/RAMEN/WING MAHSTA 짱
Hope this helps.
Carl
Hope this helps.
Carl
Registered Member
There is absolutely nothing wrong with admitting you would rather not buy a manual for whatever reason you chose to present. It's your money and your decision to take. The person who is a diehard manual lover (like myself) could give a hoot about traffic or such. Operating a manual transmission is just what is done.. like breathing; part of driving. For those who do not wish to go there, more power to them. But if you don't want a manual because you think you might not like it in traffic, then perhaps you really don't want one afterall in the long run. Once again, nothing wrong with that.
I have found over the years that by far the most common excuse someone gives for not buying a manual is driving in heavy traffic. This has led me to believe that what they are really doing is playing fence sitter or looking for a palatable excuse not to get a manual. Inside, they're really not quite certain they want to go that route, but outside they wish to appear as though they are having a hard time deciding.
Take one year of the C6 Vette, 37,372 produced, 5358 (14%) manual, and 32014 (86%) automatic.
Guess we're a lazy society.
^^ Valid points, both. I think Southern Boy summed it up... "It's your money" do with it what you will. I myself will probably be driving manual all my life, and yes, it IS like breathing. I don't even give it a second thought and that's even working and living around San Francisco (steep hills AND traffic!). Everyone's opinions are just that opinions. So again, remember it's your dime. We're all just chipping in with our experiences in hopes that it will help you avoid the 'regret' train whatever your choice may be. Welcome to the forum and happy hunting!
Registered Member
Registered Member
Just got to voice my opinion. Really don't know why one would not believe that not wanting to shift is not a valid excuse, as that is precisely why automatic transmissions were developed. I have a manual in our modified RX7 Turbo and thoroughly enjoy the fact that with the little rotary and 7200 RPM, a lot can be accomplished with that configuration, but a manual with the TL just doesn't get my heart beating faster. It's like having a Jeep Grand Cherokee with a manual just because one enjoys the shifting, but it certainly doesn't make it a better vehicle. It all boils down to the very simple question does one want to shift or not, for whatever reason. I guess the answer can be found in the sales numbers as, I'm going to say that only 5% of the TL's came with the manual. That sort of sums it up, 95% like the automatic.
But then, that is my decision to take and no one else's. Not the wife or anyone else has input in this area. And I still look forward to the end of the work day when I can get in my manual TL and take the long way home just to enjoy the drive.
