Looking for a TL Type S
Old Jan 28, 2013 | 09:12 AM
zubi23's Avatar
Hi Everyone,
My car got totaled and I've always wanted a type S and I think now Im going to do it. I checked on craigslist, and there are very limited choices... I would prefer black, because that just looks sick.. there's an 07 with 115k miles, fully loaded, going for 14,400...
my other option would be just to get a regular TL but the type s's are so much better... maybe an 05 TL, those look pretty tight...lemme know what you guys think if the 115k on the type s is alot.
Old Jan 28, 2013 | 09:20 AM
theres a lot more involved than just the mileage....
no one can tell you if the car is mechanically sound by just mileage alone.
please post the ad and or any other description of the car
Old Jan 28, 2013 | 09:23 AM
zachlone's Avatar
I bought my 05 TL with 116k miles. has a few minor issues which is normal for its age i guess. def test drive and check everything out before u buy. see if timing belt/WP has been done.
Old Jan 28, 2013 | 09:24 AM
quanaman's Avatar
TL-S
I just bought my type-s with 100k even. Meh.
If its maintained it could be worth it and you can probably haggle a little bit too.
But you should find out more about the car as far as maintenance history like the timing belt and water pump, blah blah etc.
Old Jan 28, 2013 | 09:25 AM
JTS97Z28's Avatar
It's a Honda product so as long as you can tell its been cared for 115k miles will be no issue. You will want to make sure the timing belt service has been performed. If it hasn't it will need to be done right away. The base TL's are also nice, but since 3G TL's have aged and had a chance to come down in price I would recommend looking at only 07 and 08 TL's as they have many updates/changes/improvements over the earlier 04-06's. the Type S's are very nice and for sure more unique and rare than your everyday base TL, but they are by no means in a whole different league or anything. I personally prefer the Type S myself, but base TL's are nice as well.
Old Jan 28, 2013 | 09:30 AM
zubi23's Avatar
Here is the current maintenance he says he did...
Specs & Ad-ons:
-All maintenance done up to date including: 105k service(timing belt, waterpump, & tensioner), recent oil change & transmission 3x3 flush, spark plugs, air & cabin filter.
-Slotted rotors and new pads
-Upgraded oem 3rd & 4th gear swtitches(Improves shifts point and over longevity of the transmission). Its really a night and day difference
-6k hids, hyper yellow fogs and running lights. Led bulbs for all interior and dome lights.
-Magnaflow custom exhaust(nice tone)
-OEM acura all weather mats
-Updated NAV disc
I would probably have to verify this info
Old Jan 28, 2013 | 09:37 AM
Specs & Ad-ons:
-Updated NAV disc
sounds like the seller was/is a member here.
sounds like you're getting yourself a clean car!
Old Jan 28, 2013 | 09:38 AM
erdoc48's Avatar
06 Anthracite TL
Specs & Ad-ons:
-Updated NAV disc
The change of the transmission switches shouldn't really make a 'night and day' difference. If they do, it might indicate the transmission was beginning to fail, and the switches helped, but it may reflect some issues to come.
I guess I wonder why someone would have all that work done on the car at decent expense, then sell the car (unless they got bored with it).
It might be a decent buy, but personally, I'd probably be looking for something with substantially lower mileage (if I was in the market for a used car, I'd want the mileage pretty low, say 15-20k) so I'm getting essentially a new(er) car with minimal use and the depreciation already taken out of the equation.
Old Jan 28, 2013 | 09:39 AM
zachlone's Avatar
Do it to it!
Old Jan 28, 2013 | 09:44 AM
but also more expensive.
and with it being 2013; I doubt there are any 15-20k mile '08 TL's left.
if there are a VERY few.
if the description matches the car...(being clean and well maintained) then i would have no problem scooping this TL up.
its the cars that the owners DIDNT pay any attention to; that I would be worried.
Old Jan 28, 2013 | 10:00 AM
erdoc48's Avatar
06 Anthracite TL
^^ This is true. If I wanted a lower mileage used car, I'd probably have to get something other than a Type S. I checked cars.com and there are a few with between 20-35 K miles, but the costs go up to the mid $20,000 area.
Old Jan 28, 2013 | 10:45 AM
zubi23's Avatar
Okay I'm going to go check it out.. also for the body the seller wrote:
Overall good condition, minor hail damage on hood, roof, and trunk. Got quoted from Dent Wizard of $550 to remove all dings. It is my daily and doesn't bother me at all, so haven't had it fixed or am I in no rush to.
I'm worried about the transmission issue you talked about. Is that common in TL's? It does have 115k miles so it wouldnt be covered...
how would i check if there's a problem with the transmission while test driving? and how much do you think i should offer if it feels good?
Old Jan 28, 2013 | 10:54 AM
GKinColo08TL's Avatar
The transmissions are way better in the 07-08 than in earlier years. Earlier TLs, 04-06 I believe had more issues. When you test drive, the shifts between gears up and down should be pretty smooth. You can feel the shifts but there shouldn't be any sharp jolts. When starting from a stop see if it slips. That is usually fairly easy to feel. Like a previous post, the owner sounds like a member here, ask him. Good luck. 14000 with the hail damage and 115K miles seems high to me though so beat him up about the price.
Old Jan 28, 2013 | 02:08 PM
sauceja's Avatar
Desert Life Sucks!!
Mine has less than 40k miles.
Old Jan 28, 2013 | 03:01 PM
EvilVirus's Avatar
You must be refering to the autos........6spd FTMFW
Anyway, yeah hail damage+115k does not equal to 14K so haggle him OP
Old Jan 28, 2013 | 09:40 PM
zubi23's Avatar
Okay that guy is not going under 14k. He emailed and said he rejected 14k...my a$$! Im guessing he's going to sell for 12ish...but... i checked on acura pre owned and theres a tl type s with only 55k miles .. for 24,500... How much can I haggle with the dealer? Can i walk out with the TL for 19k....?
Old Jan 29, 2013 | 07:29 AM
truonghthe's Avatar
looks who is talking when how many day you using the car within a month? like 5 days? lol.
CPO TL with that mileage the lowest they could do is $21,500 (if you are lucky) dealer won't budge that much in price. GL with your purchase.
Old Jan 29, 2013 | 08:40 PM
zubi23's Avatar
what do you mean, i am going to be using the car 5 days/week probably 7 lol. I drive a lot that's why I want something with less than 80k miles... the dealer has it for 24 with around 50k miles.... its such a sick car....
Old Jan 30, 2013 | 06:59 AM
truonghthe's Avatar
^^^^I am talking to sauceja, that why I quote his post.
Old Jan 30, 2013 | 08:26 AM
JTS97Z28's Avatar
Oh yeah, well mine has less than 30K miles haha but yeah, to find one with less than 20K like that one guy stated would be just next to impossible. They arent like Corvettes where you can find a 13 year old one with 900 miles on the odo lol. Acura owners arent that stupid!
And then even if you did find a Type S with such low mileage it will probably be listed in the high 20's.
Just curious was that car a black one listed on craigslist in the Chicago area? If so I remember seeing it up there for a while and remember a description similar to how you explained it with minor hail damage etc etc. Looked great in the pics. As for the lower mileage ones at dealers, personally I dont think your gonna be haggling them down under 20K. They just dont come down that much. Maybe a couple thousand at mostm but to get from 24.5 down to 19 just doesnt seem like something they will do. Cant hurt to try but dont be disappointed if you leave without a Type S. Also, dont forget that when buying from a dealership your gonna have to tack on sales tax and dealer fees. So even if you did get them down to 19K, when your all said and done your gonna be right back up to 22K out the door. Just something to keep in mind! Buying from private party is cheaper as far as taxes go, atleast in my state (IL).
James
Old Jan 30, 2013 | 10:35 AM
Renescent's Avatar
Have you checked the market place here?
Send me a private message; I may be interested in selling.
Old Jan 30, 2013 | 10:46 AM
Cbronze_06TL's Avatar
check the carproof or carfax reports, service histories, visual inspections and test drive...
Old Jan 30, 2013 | 11:19 AM
UA6's Avatar
UA6
Good luck
Old Jan 30, 2013 | 01:46 PM
sauceja's Avatar
Desert Life Sucks!!
Hey I drove my car the other day. True it was the first time since before christmas.
Sell it to you for 25k though.
JTS has less than 30k miles because when it hits 30k he sells it and buys another one lmao.
Old Jan 30, 2013 | 02:10 PM
Joneill44's Avatar
Specs & Ad-ons:
-Updated NAV disc
If all this is true it looks like a great buy. Take it for a test drive and let us know
Old Jan 30, 2013 | 03:35 PM
zubi23's Avatar
21 out the door would be best.. 22 is pushing it. But like you said I'm not sure if I could bring down the price with the dealer.
Yeah it is in the chicago area. I've seen it there before. I haven't gone to check it out but I called him and he said he got offers for 14k. And I'm definitely not paying 14k for a car with 115k miles.. .and with hail damage, complete rip off.
I've seen some at the dealer with apprx 50k miles running for about 24ish...
James
Old Jan 30, 2013 | 09:45 PM
truonghthe's Avatar
sorry but I only want to buy TL-S MT KBP with Ebony/silver color :P.
Old Jan 31, 2013 | 12:22 PM
sauceja's Avatar
Desert Life Sucks!!
I can rattle can it black but the price goes up to 32k. lol
Charles Bennett
Jan 28, 2018 08:53 PM
Jul 16, 2017 07:33 AM
mvidal6
ILX
Nov 14, 2015 07:43 AM
justin.w13.walker
Sep 22, 2015 02:21 PM
