Lights are flickering. Please help.
Old May 30, 2021 | 05:44 PM
itsrayvennn's Avatar
So i've already replaced bulbs in my headlights, installed a new battery, checked the fuses and got the alternator benched. Lights are still flickering and still showing signs of electrical issues. Any advice will be helpful, thanks!!
Old May 30, 2021 | 05:53 PM
gatrhumpy's Avatar
Chapter Leader
(Northeast Florida)
Check all the ground points in the car. One could be loose.
Old May 30, 2021 | 05:57 PM
Okay thanks! I'll check that next before i bring it to a shop. Was also thinking it might be some wiring issues.
Old May 30, 2021 | 09:58 PM
Jackass's Avatar
Pulsing? Going on/off constantly? A bit more description would be helpful here. Does it behave differently if the engine is on or off?
Old May 30, 2021 | 10:07 PM
Yeah man, the headlight and turn signals will be flickering as well as the turn signals on my dash. It also does this both when the engine is on/off.
Old May 31, 2021 | 05:21 AM
DMZ's Avatar
DMZ
Head a da Family
Ground connection somewhere.
Old May 31, 2021 | 10:19 AM
Pair of TLs's Avatar
Originally Posted by dmz
ground connection somewhere.
this!
Old Jun 10, 2021 | 03:47 AM
Blakep93's Avatar
I have had the same issue for a while with my car and couldn't figure it out, everything I could think of pointed to a bad ground like everyone is suggesting... And logic agrees with that... With that being said about a month ago it wouldn't start because the alternator finally gave out and the car wouldn't start, I replaced it and my lights no longer flickers, I'd be willing to bet you'll solve that problem when you swap alternators and I wouldnt worry too much about it as long as its just the dome lights that was the main thing that flickered with mine
jacobsee
1/2G MDX (2001-2013)
Mar 5, 2015 01:11 AM
BlueAc
Dec 9, 2008 07:23 AM
Ayu688
Dec 9, 2007 11:34 PM
cl_jay
Apr 18, 2005 09:46 PM
98GREENSTREAK
Apr 25, 2002 07:13 AM
