LED turn signal bulb
Old 09-15-2015, 03:14 AM
pplcrew's Avatar
Hi azine members,
I have just replaced my turn signal bulb with LED 50W power and I noticed the bulbs are brighter than my headlights.
Should I change my headlights to brighter one or equivalent to the turn signals ?
Let me know how you all think !
Attached Thumbnails LED turn signal bulb-img_8882.jpg   LED turn signal bulb-img_8883.jpg
Old 09-15-2015, 09:15 AM
EvilVirus's Avatar
Received 1,120 Likes on 893 Posts
Since it bother you enough, the obvious answer is yes. Your fogs too.
Old 09-15-2015, 09:18 AM
Received 8,662 Likes on 6,685 Posts
and your dome and courtesy lights and your map lights and license plate lights...
you can't let your front turn signal take away the thunder from the rest of your car!!!
Old 09-15-2015, 09:21 AM
EvilVirus's Avatar
don't forget the trunk light
Old 09-15-2015, 09:24 AM
oh and those damn vanity lights... those are the worst to remove..
Old 09-15-2015, 02:07 PM
Jackass's Avatar
They don't look brighter to me in the pics...just a higher temp with a more blue/purple hue.
And they aren't 50W LEDs. If you plugged in something to that socket that pulled 50W, you would melt the socket and/or harness.
Old 09-15-2015, 02:19 PM
Yup.. common misconception when it comes to LEDs.. crappy vendors like to use the wattage to trick people, it's really a marketing tool..
When they state 50w, they're saying that it is comparable to an incandescent bulb running at 50w from a luminosity perspective. LEDs draw considerably less power while also are brighter..
LoveMyTL-S (02-03-2021)
Old 09-15-2015, 05:10 PM
pplcrew's Avatar
Any suggestion what to get for headlights ?
Also the fog light, preferably yellow, since it's all white.
Old 09-15-2015, 08:28 PM
Jeff
Oh Sickest TL's Avatar
morimoto xb35? I got 6500k theyre white with a lil blue in them . You should've got switchbacks for the sides.
Old 09-20-2015, 03:24 AM
pplcrew's Avatar
That looks great !
Old 01-29-2021, 09:45 PM
Sheri Lynn's Avatar
Acura tl lights
Okay so I've been reading and researching but I haven't found anybody with the similar problem. I just got my acura this last christmas. It came with a headlight out. Then the driver side quite working (fog, headlight) So basically I ordered new hid bulbs for my headlights and new fog light too. So I replaced all the lights and when put back together I have both fog lights but now I have no headlights. This makes no sense.. I'm so confused, and yes I've checked fuses bulbs again please help
Old 01-30-2021, 08:59 AM
peter6's Avatar
Is everything plugged in? Igniter correctly secured to the HID bulb? Did you get some decent bulbs or some ebay garbage?
Get to the ballast plug, check if it's receiving 12V, use test light not a voltmeter.
Fernando Enciso
05-01-2021 11:34 AM
brooklynn_ boy
01-14-2015 10:45 AM
colindunn
05-21-2013 09:22 AM
Pete2010
10-18-2011 07:45 PM
Quick Reply: LED turn signal bulb
