LED License Plate lights- Hopefully flicker proof
Did my homework around the board for putting LEDs in to light the plate. I suspect a factor in just replacing the bulbs with LED units is the fact that the resistor is suspended from the ends. Looking at different models of units that work great in a rough enviroment I found out that they are all "potted" units. This is when the LEDS and electronic goodies are encased in a hard resin, thus giving everything solid support and keeping it from moving.
on tek-toys and superbrightleds.com they have this unit. I ordered 2 as I wasnt sure how I was going to do this.
We've all seen how to take the stock lights out so I wont explain it. I removed the trunk lid liner and got the room I needed. Pictures explain this a lot better:
The silver you see behind the lights are just simple cut outs that are wedged between the back of the light and the trunk metal. A little bit of silicon to keep the weather out and all is well. Also worth noting was I drilled a pass thru hole for the power wires.
Using your basic power theifs it was fairly easy to wire. The worse part was cutting away factory tape
and hows it work - Well I had spent a lotta time grinding down some shims and making the plate lit but minimal over cast onto the bumper. Welp I overtightened the lights and tweaked it outta whack. As for light output I think it works fine
How it looks in the day time -
And night-time
And night-time
Originally Posted by DMZ
Nice work, but do you really want to make your plate # easier to see?
Tried and true PIAA.
Blazin with your Moms in
acura-cl.com OG
http://cgi.ebay.com/ebaymotors/2pcs-...spagenameZWDVW
i used those from that seller. fast shipping from HK, great quality product!
RAR
Originally Posted by Kennedy
I replaced all my wedge type bulbs (interior, license plate, and reverse) with these from superbrightleds.com
LED Wedge Base Bulbs:
The're crazy bright, and haven't failed yet. You guys have to try these.
I bought a set of amber 9 led bulbs from tek-toys and one of them started to flicker. I took it out and made sure everything look good and put it back in and it was still flickerking. I emailed Brian at tek-toys back about the probably twice and still havent had a reply yet. I guess after about 8 months of use your on your own. Good luck to everyone else.
OMGWTF4THGENTL
Originally Posted by leedogg
we need pics
Dougler,
I've tried the 9 led and 12 led clusters... The 12 led clusters you're linked to on ebay are 3 dollars cheaper from superbright leds. I use those (blue) in my door panels. For reverse lights, consider the led I listed above.
Leedog,
I need xtin to come back and take the photos. I suck at taking pictures, especially at night.
Trust me, those tiny HP single LEDs are the bomb. screw the fragile 9/12 led clusters, these are the ones to have. They're brighter than the stock reverse lights.
Leedog,
OMGWTF4THGENTL
Originally Posted by deke
Those are only 1 watt LED's right? I recall seeing some 6.5 watt single unit LEDs somewhere....
3W "luxeon" perhaps?
http://www.superbrightleds.com/tail-brake-turn.html
but alas, no wedge version of that yet it seems.
The 1 watter I listed above is potted as well...
Luxeon III 190 lumens.
if you but 10,000+ they are only 3.15 a pop...
Too Fast TOO FURIOUS
Hold the onions
They will but wont be very bright. Im thinking of putting some h3 bulbs into my reverse housings...
I also had LED backup lights and put back the stock bulbs. They were way too dim and useless. I do have LED turn signals all around no relay so RICER blinking speeds.
King of NYC
rcs86
08-02-2016 06:52 PM
