LED hyperblink fix
Old Sep 10, 2024 | 07:18 PM
208kTL's Avatar
LED hyperblink fix
Just seeing if this fix has changed since 2011? I know you can do the resistor swap
Old Sep 10, 2024 | 08:00 PM
jayee's Avatar
Hyperflashing happens because LEDs draw less power than a halogen bulb, putting less load on the line and making the car think the bulb is out. Adding more load to the line is the only way to send the correct signal to the car so that it does not think anything is wrong and the simplest way to do this is by adding resistors to the line.
I'm not sure if anyone makes these for the 3G TL but there's plug and play harnesses that fix hyperflashing for some cars. At the end of the day though, they're still just a resistor in a case.
Old Sep 10, 2024 | 08:04 PM
208kTL's Avatar
Thanks for the reply. I'll follow the resistor route from this thread, soldering isn't a big deal really
https://acurazine.com/forums/3g-tl-2...istors-815219/
Old Sep 11, 2024 | 07:58 AM
jayee's Avatar
FYI, I just stumbled upon LED turn signal bulbs that have the resistor built into the bulbs so that it draws the correct amount of power.
Here’s an example from Amazon:
OXILAM 7440 LED Bulbs Amber Yellow 4000LM for Turn Signal Lights with Build-in Load Resistor CANBUS Error Free T20 7440NA 7441 W21W WY21W Blinker Bulb Replacement (2PCS) https://a.co/d/fJpeMcL
Old Sep 11, 2024 | 08:03 AM
208kTL's Avatar
I actually came across those originally but they don't have red unfortunately. At least I can use those for the front though
Thanks for the link.
Old Sep 11, 2024 | 08:50 AM
Resistor mod is easy and definitely recommended. Unnecessary to add resistors in parallel to the bulbs. It's the best option truly.
Old Sep 11, 2024 | 08:51 AM
Jackass's Avatar
If your rear lens is red, the amber bulb will be fine.
Old Sep 11, 2024 | 12:08 PM
208kTL's Avatar
I'm likely going this route as it does seem very simple and easy.
It wouldn't be a mix of red/orange? I'm sticking to the resistor mod anyway since I already have the bulbs in hand
Old Sep 17, 2024 | 11:25 AM
Taseen Syed's Avatar
Instead of soldering in resistors and such, I just swap the flasher relay. I've done full LED conversions on my Accord and motorcycle and by swapping out the flasher relay, you don't need to solder anything. Just pop in LED bulbs and hyperflashing is gone.
This is what I used for my TL
Amazon Amazon
Old Sep 17, 2024 | 12:11 PM
208kTL's Avatar
Whaaaaa. This is a direct replacement!?
Old Sep 17, 2024 | 12:13 PM
Correct, direct replacement plug and play. Be warned....taking out the old relay flasher will be a PITA. Just take your time with it.
Old Sep 17, 2024 | 12:20 PM
208kTL's Avatar
What a hero! I'm going away tomorrow but you've given me something to look forward to when I return, thanks for the tip as well
Dragon27
ZDX
May 12, 2015 07:17 PM
guitarplayer16
Mar 2, 2012 06:09 PM
harminder247
Mar 20, 2006 06:27 PM
Leviathan
Mar 7, 2006 07:04 PM
