LED DRL not working
LED DRL not working
All of a sudden one LED DRL is not working right. One is on but only a small amount of power enough to light the actual bulb but not provide lighting power enough to see.
any thoughts on how to fix or is the LED going dead?
I have had this issue on my AV6, but I have regular halogen bulbs. Had to change out the DRL fuse even though the fuse wasn't blown, it fixed the issue. I suggest you try the original bulbs first to make sure there is no circuit issue first.
I would also recommend checking the grounding point on your iJDM harness. My led bulbs went out and I assumed that the bulbs were bad or the harness had malfunctioned. In reality, all that I needed to do was scrape the paint off of the connection point and both lights worked immediately.
