Knock Sensor
Old Mar 27, 2009 | 07:15 PM
ducati748R's Avatar
Knock Sensor
I stopped by Autozone today and had them scan my car for codes since the check engine light suddenly came on. They hooked up their OBD II scanner and discovered code P0325. So, it looks like I have a bad Knock Sensor. I did a search and found a good DIY from jdb8805. Thanks man for the DIY! Anyway, has anyone else attempted this repair themselves? Any shortcuts or tips you guys have? Also, does anyone have a pic of the updated wire/sensor that's supposed to be more rat/mouse resistant? LOL
Could it be something else besides the Knock Sensor?
Old Mar 28, 2009 | 08:10 AM
ducati748R's Avatar
Can someone verify that this is the correct part number for the knock sensor?
Thanks for the help...
Part #1 in diagram
30531-RCA-A01 SUB-WIRE, KNOCK SENSOR 2004 TL $3.14
Old Mar 30, 2009 | 06:53 PM
ducati748R's Avatar
Come on guys and gals. Over 60 views and not one single response! Help a brother out. What happened to all the members complaining about having this issue... Looks like a pretty straight forward DIY, but I'd like to make sure I get the right replacement/updated part before i jump into it. Especially since it's kind of a PIA to do...
Old Mar 30, 2009 | 08:07 PM
tiredandhungry67's Avatar
i had a knock sensor reading, and it turned out the rats went into the little V compartment under the car, which is common in V6 cars, and it chewed the wires since it was hungry. normally, that is a $400 fix, but the idiot rat was f*cking starving, so he chewed up most of the wires, causing for a $1500 fix for a new engine wiring harness.
get it checked asap. has it rained recently in your area or been really cold? because the rats come looking for shelter when you tunr your car off since the engine is still hot.
Old Mar 30, 2009 | 08:30 PM
tonyph33r's Avatar
hhhh
Old Mar 30, 2009 | 11:56 PM
ducati748R's Avatar
Will do, thanks man. I'll have Autozone clear it and see if it comes back. It blows my mind that Honda engineers used a material that attracts rats! WTF!!!!! There was enough of an issue that they re-designed the wire/sensor but those of us that are having the problem are still SOL.
Florida did go through a cold spell this winter and I kept the car outside while I refinished the garage floor and worked on another project, so it may have happened then. I still find it hard to believe! I wish I could visually check the wire before I rip it all apart. Sorry to hear it was such a huge financial pain for you bro.
Maybe I'll take the opportunity to port the intake manifold while it's off...LOL
Originally Posted by tonyph33r
hhhh
Are you trying to say something?
RobbDizzle
Oct 15, 2015 11:16 AM
thegipper
Sep 28, 2015 01:01 PM
hrothgar02
Sep 28, 2015 11:08 AM
prbori
Sep 27, 2015 01:37 AM
STL TL-S
Sep 23, 2015 08:52 PM
