Just making sure
Old Nov 21, 2008 | 08:40 PM
typesowner024's Avatar
Just making sure
Does anyone know if it is bad to shift my automatic TLS from drive to neutral whil driving at slow speeds so i can rev the car a little for show?? will it mess up the car?
Also does anyone have this problem i have:
Often times when i accelerat quickly the car stays in first couple gears a little longer than usuall, its like over reving the enging and idk why? I expect it to change gears due to the sound the car makes, and sometimes it doesnt, and it takes a little longer and doesnt shift when its supposed to. is it possible that the gears or somthing is messed up? Its not shifting incredibly later but it it notible and it only happens sometimes not always.Let me know
Old Nov 21, 2008 | 08:47 PM
Bearcat94's Avatar
AZ Community Team
Don't be a dick.
In full auto mode (D), the car will change gears based on throttle position. The harder you press the pedal, the longer it'll hold the gear.
You will not "over rev" in auto. The car won't even hit the Rev Limiter (which is basically the red line on the tach). The engine management will not allow you to go past the rev limiter in any gear.
When in Manual Mode (SS), for the 3G TL-S the car will hold *all* gears until you shift. *You* have to shift to avoid the rev limiter.
Hitting the rev limiter is a waste of momentum - it basically cuts the gas momentarily. To avoid the rev limiter, in SS, shift ~300 - 500 RPM before the redline.
Old Nov 21, 2008 | 11:01 PM
paliknight's Avatar
Originally Posted by Bearcat94
Don't be a dick.
true. also, in SS mode, if you dont shift, the car will shift for you.
and this thread doesnt look too good. 16 year old+40K car= ultimate fail.
Old Nov 21, 2008 | 11:51 PM
Blazing GT's Avatar
Don't be a dick.
Old Nov 22, 2008 | 04:35 AM
mattster's Avatar
Driven to Perfection
this is why 16 year olds shouldn't get new TL's from mum and dad.
Old Nov 22, 2008 | 06:35 AM
if idont change gears in manual mode too quickly is it bad for the engine? Like if i let it rev a little higher and get the engine noise up a little louder.
Old Nov 22, 2008 | 06:37 AM
enigmaos's Avatar
Too Fast TOO FURIOUS
Old Nov 22, 2008 | 06:43 AM
and is it bad to shift to neutral when in drive and driving slow and then shifting back to drive?? will it hurt the gears or anything?
Old Nov 22, 2008 | 07:10 AM
SQAcuraTL04's Avatar
This thread should just be locked and deleted. Let's save people from wasting their time. I know I just killed about a minute of my time reading this garbage just for curiousity sake. That's 1 minute that could have been better applied to other posts on Acurazine. :-(
Old Nov 22, 2008 | 07:23 AM
csmeance's Avatar
lets be nice and help him out, no need to bash him for what he wants to do with HIS car.
Old Nov 22, 2008 | 09:07 AM
Trew's Avatar
Does anyone know if it is bad to shift my automatic TLS from drive to neutral whil driving at slow speeds so i can rev the car a little for show?? will it mess up the car?Thanks
You won't hurt anything if you shift into neutral while moving, even at highway speeds. So go for it. You may even get laid looking so cool!
Old Nov 22, 2008 | 09:57 AM
Blazing GT's Avatar
To OP:
your mom and dad bought you that car to get from point A to point B and you got a TL-S. Don't worry about doing these tactics. You will eventually mess the car up. It is a A/T. If you want to learn manual do what I am doing. Buy a cheap and when i say cheap (1000$ or less) car with a M/T and learn how to use the transmission from there.
good luck.
Old Nov 22, 2008 | 10:31 AM
Will Y.'s Avatar
Registered but harmless
Check your owner's manual- that willl have the answers to every question you've asked so far.
An on-line version of the manual is available in the 3G Garage here as well.
Congrats on the car, and please drive safely.
Feb 25, 2020 09:57 AM
cycdaniel
Dec 17, 2019 10:58 AM
The Machine
Sep 24, 2018 08:27 PM
pistacio
Sep 26, 2015 09:45 AM
