It's slippery out there...TL got hit while parked
It snowed a bit in Denver yesterday. When I came home, I knew I should pull into the driveway behind my wife's car, but she leaves earlier than me in the morning, so I would have had to get out of the warm bed to pull the TL out so she could leave. Here's what happened:
http://imgur.com/a/YzzuE
Dang, sorry to see that happen, seems like you came out alright though, maybe a new bumper and headlight?
damn sorry about that man. I'd have insurance give you the green light first. you lose a bit of structural integrity with a damaged bumper. not that you expect to get hit again. i probably would sit that one out, then again, the damage *that* bad.
Should I have the adjuster come out and cut me a check, then try to find the cheapest repair estimate and hopefully use the difference to upgrade the bumper?
So, how should I go about doing that? I've been in contact with both insurance companies and spoke with one body shop. I'd like to get the A Spec front bumper or the Type-S, but I don't want to spend a dime out of pocket (bad timing with Xmas.).
here is what i would do. take the car to a few different body shops (as long as its driveable)...which it seems to be, and get a few different estimates from them. take the highest estimate you recieve, submit that to your insurance company, they'll cut you a check, and you use that money to buy a new type-s front bumper...they are around $260 shipped. you can get it painted for around the same price.
this is all dependent on how much your insurance check will be for, and keep in mind that the type-s bumper also requires some additional add-on pieces like the mesh grill, fog lights, etc.
there is no aspec front bumper. there is only base, or type-s. aspec items are add on pieces to the existing bumpers.
Also, if I go and just get an estimate and a check from insurance, what happens if there actually is more extensive damage that wasn't caught in the original estimate? Isn't there a chance I would already have the check from the insurance co. and be stuck with paying for the additional repairs?
huh? A/S works fine in snow its those summer tires that are useless in less then an inch of it
, Glad no one was hurt especially that baby
It will depend on your insurance. My adjuster came out to create the estimate, and then worked with my shop to keep everything reasonable.
I just had my TL fixed last week from damage that resulted from the snow storm that came through 2 weeks (we're in Castle Rock). Long story short (hit a curb on ice), I was trying to see if one of my struts was damaged how I could get insurance to chip in towards coilovers, but at the end of the day the strut and springs were fine. If they had been damaged, they would have given me money for the value of an OEM part that I could use towards the coilovers. I would start by looking at oemacuraparts.com, etc., and seeing what the msrp is of your bumper compared to a type-s. Odds are you could just pay the difference and get it done. If you don't want anything out of pocket, you may have to get a shop to find a used type-s bumper to put on/paint/etc.
Oh, ok, gotcha. So getting a new base front bumper and an A spec front lip is probably not going to happen without me paying for the lip, right?
when you take it to a few body shops, they'll look over everything and check for further damage. if for some reason there are more extensive damages found later, that same body shop will inform your insurance and they'll cut another check for the additional damages found.
you may be better off (money wise) to just get a new base front bumper for now, and POSSIBLY have enough to add an aspec front lip (theyre around $260 shipped and they come painted). this is all dependent on what estimates you get. if you get an estimate of $900, you can certainly buy a new bumper from AckTL05 for $260, get it painted for $250, and get a new aspec lip for $260...and you'll even have some money left over for stocking stuffers.
Some all-season tires are obviously better than others, but I'm now a snow-tire advocate through and through when it comes to the TL.
I just got the same tires put on 2 days ago. I thought they did great in this last storm too. Probably the best A/S I've used. I didn't want to spend double to get Michelin PA4s + wheels just for a little better traction a couple weeks a year here in Denver...
Does anybody know if I have a body shop do the work, will my car now show up on carfax, etc. as having been in an accident with body work? That would give me even more incentive to buy a new bumper and put it on myself.
3G TL/2G MDX Owner
^^depends on the shop. some shops do not report to car fax. insurance might report, but usually if the damage is above a certain dollar amount. the shop i use does not report to car fax.
I had the car inspected by an independent body shop yesterday and they found a couple of things beyond the damage to the bumper:
I think he said this is the resonator assembly? Part of it is broken off.
The headlight got pushed out of place:
Here you can see how the paint is cracked slightly (I know my headlights are hideously hazy-I've tried the kits):
Headlight not flush and a small crack in the paint:
Then there's this part, not sure what it's called, the metal is bent:
Since there's this kind of damage, I guess I should have the shop do the work and forget about ordering a new bumper and lip to put on myself? Or I could just have them do the paint and metal work and do the rest myself to save money?
3G TL/2G MDX Owner
is it worth the hassle?? the car is already in the shop...let the professionals take care of it save yourself any grief. if they mess it up at least you can get them to fix it again...if you mess it up...well...
my time is more valuable to me, if you're going through insurance, then all you have to do is pay the deductible and be done with it. let the shop do it. up to you.
So I got the car back a couple of weeks ago, and I immediately noticed that the area behind the grill looks different. It looks like there's now a housing for fog lights but I'm not sure:
I have an '04. Did they give me a bumper from a later year that has the fog light housing? If so, can I add fog lights easily now? On the final receipt I got, it says:
REMOVE/REPLACE Bumper Cover
Add for fog lamps
Add for fog lamps
It's normal.
Looks different because of the white paint.
Stock plastic color hides those black gaps and etc.
Right front has to be close like that
Left front top gap is for intake
Positive
If you want it black, then take it back.
Positive
They painted the whole bumper without looking at your old bumper. Id take it back and have them paint it black. You could donit yourself but its not worth it because they should've of done it right in the first place. Good luck.
4drviper
Apr 23, 2025 07:13 PM
poor car.
