Interior Lights + LED kit = blown fuse...HELP?
I recently installed a 9LED(blue) kit in my car about 30 days ago. Just last night my interior lights went out and figured it was a blown fuse. well i was right, and when i replaced the blown fuse the lights lit up again, but then blew almost immediately.
anybody have any suggestions as to what the problem might be?
has anyone else had any problems with their LED kits blowing fuses?
If it happens with the normal incandesent bulb too you are using too small a fuse. You could put a bigger fuse in, BUT that could melt some stuff. If it doesnt happen with the incandesent bulb go with the 6LED set up since that seems to work better for people.
Youse Gots Sacked
9 LEDS and i havn't had any issues...im sure it might be a defect in one of the bulbs....do what Wolftag said and if thats the case...if you bought them on EBAY he will exchange them for a brand new set..
Originally Posted by tjker
everything works fine now. changed fuse(for 2nd time), and am having no problems. not really sure what happened....
maybe a bad fuse? i don't know
check that............blowing fuses again!!!! here is what i have found. the lights in the door work fine, but when i try to turn on the overhead interior lights is now when the fuse blows.
do i try each and every bulb in one of the doors and eliminate which bulb is causing the problem
or, could there be a problem with the one of the overhead sockets itself
MAN, THIS A BUMMER!
It takes a while for the fuse to blow because it takes time to heat up and melt.
That means that its probably not a short, otherwise it would blow out immediately.
You are simply overloading the circuit with too many high powered bulbs. You can replace some or all of the bulbs with something that draws less power.
You definately don't want to use a higher current fuse -- then it will be a wire that heats up and melts
Make MyTL Great Again
MAN, THIS A BUMMER!
MAN, THIS A BUMMER!
LED's don't draw much power...
LED's draw a fraction of the power of filament bulbs, so overloading the circuit with "high power bulbs" isn't the problem. I'd be inclined to think that it's one of the sockets creating the problem.
The bulbs in the overhead lights come out very hard and it's very possible a socket got damaged during removal thats causing a short. The other thing might be a bad LED.
I'd suggest leaving one of the overheads out and see if the fuse blows, that should isolate which of the two is the source of the problem.
If the fuse doesn't blow, then swap the LED's in that socket. If the fuse blows, you know it's the LED that's bad, if it doesn't then you know it's the empty socket thats the problem.
I got my LEDs from hereAuto Lumination
I am using 9LEDs in both doors, two front overhead lights, and two rear overhead lights...total of 6 bulbs
After work tonight, I am going to try each bulb in the drivers side door. this door seems to be having no trouble, and hopefully i can eliminate whether its a bad bulb, or a bad socket. now i just have to go buy more fuses to test this.
i'll give you an update later tonight
Ok, i have found that the front overhead left LED was the problem. After testing the bulb in the door, and blowing yet another fuse, i found this was the only bulb causing this issue.
I then tested the OEM bulb in the overhead with the rest of the LEDs still plugged in in the overhead lights. OEM bulb worked fine, as well as the rest of the overhead LEDs.
Conclusion: bad LED bulb(thank god), and not a bad socket.
I hope i have solved this issue. Now i have to email auto lumination to see what we can do to solve this problem. Now, lets see what sort of customer service i receive concerning this issue.
rockyboy
01-25-2016 06:00 PM
handsom-hustla
11-13-2015 05:04 PM
