Instrument dash lighting
Old Nov 25, 2003 | 11:09 AM
7th Gear
Question Instrument dash lighting
I dont have a TL yet but I hope to within 6 months so I can't test this. I read in another thread that the instrument backlighting defaults to full brightness when you turn the car on. Is this true? It seems that it should stay where you left it last and not go to full bright. Also is this the volume speed sentitive? or does it not have to be since the car is so quiet that there is little road noise coming through at higher speeds
Old Nov 25, 2003 | 11:37 AM
elbodude's Avatar
Re: Instrument dash lighting
Brightness stays the same as you left it.
You set the volume manualy, not sure if it is speed sensitive.
Old Nov 25, 2003 | 12:44 PM
Right. And there is also very convenient "MAX" button next to the "brightness +/-" control. You push "MAX" once, and the lighting goes into the "daylight" mode, which means full brightness for the LEDs and "daylight" mode of the navigation system.
Then you press "MAX" again, and the lighting goes back to your previously configured settings.
VERY handly when/if you need to put your headlights on at daytime.
Old Nov 25, 2003 | 12:50 PM
mook's Avatar
I don't think the volume is speed sensitive. I have found myself adjusting the volume when going to or slowing down from highway speeds to compensate for road noise or the lack thereof.
Old Nov 25, 2003 | 03:07 PM
brandomc's Avatar
Max and Navi
Another useful tip...
If you Navi screen is set to auto and you have your running lights or headloghts on in the daytime, then the navi screen turns dark (thinks it's night). If you push the MAX button then it switched the Navi screen to daytime mode.
...I think I got that right...
mada51589
Jan 9, 2025 04:40 PM
rockyboy
Aug 4, 2024 10:35 AM
BoricuaTL
Apr 8, 2016 01:08 PM
Rob144
Sep 21, 2015 08:18 AM
Greengecko
Sep 16, 2015 08:19 PM
