Install Failed? HID Bulb Replacement....
Old Apr 4, 2008 | 08:15 PM
xoulu's Avatar
Ok guys, so I was getting my car repair for bumper issue, and I had the headlights shipped off for angel eyes and custom paint. I installed the replacement bulb from Kaixen 8500k and when I turned it on everything works. All my LED works, i like the fast blinking from the switchback. But the reg beam dont work. It turns blue but gives no light. Did i install it wrong? Not enough power maybe? Any clues? Thanks.
Old Apr 4, 2008 | 09:22 PM
rbf351's Avatar
Registered User
thats what you get for using an 8500k light, go back to stock, and you'll have usable light
Old Apr 5, 2008 | 09:27 AM
Tripnbeats's Avatar
yea i wouldnt use anything but the stock bulbs....i got 6000k philips ultinon bulbs with no prob and i had 6000 ge bulbs but no visibility from them..... plus anytime id try to use aftermarket bulbs the ballasts would blow so F*** that no more acura trips for me.
Old Apr 5, 2008 | 10:12 AM
xoulu's Avatar
yea im trying to find a 6000k or 6500k philips
Old Apr 5, 2008 | 12:27 PM
rockyfeller's Avatar
King of NYC
Hmmm OK difference of opinions here but......
I run 8000K lights. Granted less output but I have good eyes, I love em. Never blown a ballast over a replacement bulb either. Bad luck for you I guess.
xoulu something else is wrong here hardware related.
Old Apr 5, 2008 | 03:38 PM
xoulu's Avatar
i do think so too, beacuse less light is comming out, i can't even see at night unless i turn high beam on.... with high beam its like normal 4300k
Old Apr 5, 2008 | 04:00 PM
JnC's Avatar
JnC
Former Sponsor
You think things are bad now? Try driving in rain/poor weather with those damn things. Installing anything beyond OEM spec HID bulbs negates the whole idea of having HIDs in your car. To give you an example how poor these things are, a standard BNIB OEM HID bulb such as Phillips 85122+ is rated at 3400 lumens, Osram D2S (standard on 3GTL) is rated at 3400 lumens (both are at 4300k color). Compare these numbers to Phillips Ultinon 6000k which is 2400 Lumens, GE is 2200 Lumens, any one of those aftermarket higher K bulbs are around 2000, a standard halogen is rated at 1400 lumens. So you might as well put some halogen blue bulbs in your headlights.
Granted its a personal choice but driving around with headlights that look like they just chocked on papa smurf is not going to do any good. Be more worried about what you see at night rather than what the on coming traffic does.
/rant.
Old Apr 5, 2008 | 04:53 PM
d2mChris's Avatar
8k Bulbs are fine, seems somthing is wrong with the bulb or the install, I am not sure tho.
Old Apr 5, 2008 | 06:23 PM
xoulu's Avatar
gah i'll order the philips 6000k for $110 shipped and install it and see if theres a difference
Old Apr 5, 2008 | 06:47 PM
BLACKURA_NY's Avatar
I have car ADD
id like to see some pics of the phillips 6500K
i had kaixen 8500k, within 2 weeks, one bulb turned green.. i am currently awaiting my replacements from Kaixen. they did offer to send me a new pair without any hassle....
the light output decrease was definitely there, but it wasnt HORRIBLE... still, not as good as OEM 4300K, but i love the look
Old Apr 5, 2008 | 09:40 PM
Tripnbeats's Avatar
they look diff im not crazy about the color i was thinking of going with osram 6000... hard to find though
Old Apr 5, 2008 | 10:25 PM
xoulu's Avatar
hmmmm whats Kaixen's number I need to give them a call hahaha, swap it out for a 6000k would ok for me
Old Apr 5, 2008 | 10:30 PM
I have car ADD
i emailed them @ sales@kaixenkits.com
Old Apr 5, 2008 | 10:32 PM
I have car ADD
do neither of your headlights work?? if so, i doubt TWO bulbs were defective, you might not have plugged the ballast power harness back in. if thats the case, it shouldnt power up at all, but i would check your connections anyways, there should be 4 wire harnesses plugged into your each of your headlights
Old Apr 6, 2008 | 04:14 AM
xoulu's Avatar
yep I did, put the oem ones back in and BAM I CAN SEE!!! and i put the 8500k back in and barely any light. Will email them. THanks
Old Apr 6, 2008 | 07:47 AM
JnC's Avatar
JnC
Former Sponsor
If you really want to upgrade your stock lighting then just upgrade to Phillips 85122+ D2S bulbs. They are not smurf colored but are indeed brighter than the stock Osrams.
Old Apr 6, 2008 | 04:44 PM
Integra's Avatar
2007 Acura TL-S
something is wrong with your bulbs.. 6k should be very visible and im running 8k's and they are fairly bright.
Old Apr 6, 2008 | 07:00 PM
ed99's Avatar
9.5+10.5 22m=Hella Flush
Just wondering if you have these Phillips 85122+D2S bulbs on your car? They are 5000k so must be a bit whiter than the OEM 4300k correct?
Old Apr 6, 2008 | 07:08 PM
JnC's Avatar
JnC
Former Sponsor
85122+ are not 5000k, 85122CM (ColorMatched) are 5000k. 85122+ are rated at 4200k and 3400 lumens, compare that figure to a brand new Osram Xenarc bulb (thats what you have in your TL from factory) which is rated at 4300k and 3200 lumens. Since your bulb is nearing its death I'd say its producing around 2400 lumens or may be even less. The thing with 85122+ is that they dont loose their intensity over their life i.e. they dont color shift.
Old Apr 6, 2008 | 07:23 PM
ed99's Avatar
You saw my recent post of one of my pink eye HID; therefore, I will be replacing them with after mkt HID bulb. If I do buy the Phillips I might look into the 5000k colormatched since I want something whiter than OEM. Have you seen any pics of the 5000k philllips? If so, they should be whiter than OEM correct? Thx!
Old Apr 6, 2008 | 07:33 PM
Kennedy's Avatar
OMGWTF4THGENTL
Props to JnC for showing up...
I've been lecturing these facts for a while.
Sometimes your talking to a wall though.
Old Apr 6, 2008 | 07:51 PM
JnC's Avatar
JnC
Former Sponsor
Its alright bud, I have been there myself as well when I was more worried about what on coming traffic sees coming out of my cars headlights rather than how good I see at night myself. As I said earlier, putting a higher kelvin bulb in your HID headlights negates the whole idea of having HIDs in the first place.
I am not sure what is the built quality and specs are on the Kaixen HIDs but I can bet you this that they are not as good as products by GE, Phillips or Osrams.
To people who believe in color here are few spec sheets to show you how bad the numbers are when you go higher in color. Pay close attention to the number of lumens, thats the light intensity.
BTW just for references a standard halogen bulb produces 1100~1400 lumens.
Philips 85122+:
85122CM:
Philips Ultinon:
GE 4200K:
GE 5100K:
GE 10000K:
oo7spy
Jun 19, 2023 12:48 AM
BoricuaTL
Apr 8, 2016 01:08 PM
InFaMouSLink
Oct 27, 2015 06:51 PM
pozebly
Sep 23, 2015 07:30 AM
pesobreeze
1G RL (1996-2004)
Sep 3, 2015 12:26 PM
