I have the shakes, anyone else?
Old Oct 11, 2004 | 03:17 PM
dv8ing's Avatar
someone elses Avatar?????
Okay so maybe this is different than other shakes and vibrations.
When braking at any speed above 65mph, I get some crazy shakes in the steering wheel the more pressure applied to brakes the more noticeable the shakes become if speed is above 80mph and brakes are applied you would not believe how bad it shakes, it stops shaking around 40mph or so.
any ideas as to what the problem might be, got about 15k on the TL now and just recently started to notice it.
Old Oct 11, 2004 | 03:23 PM
zeezz's Avatar
Team Anthracite Webmaster
check your tire tread wear. also check your tire pressures to make sure they are all equal. you might need a rotation/balance.
Old Oct 11, 2004 | 03:26 PM
Ron A's Avatar
Administrator
Go get your rotors checked. Have you driven through water lately after getting your brakes heated up? Sounds like the rotors may have warped. I am not sure why this would happen only above 40mph, but it is definitely something to have checked at the dealer.
In any case, my motto is that if it won't start I can always get it to the dealer somehow, but if it won't stop, then I have a problem, so I always pay more attention to my brakes.
Old Oct 11, 2004 | 03:28 PM
dv8ing's Avatar
Yeah i kinda figured that, thanks for the quick response. but if i may add my brother owns a 03 TL and he had the same problem, ended up needing a brake job not sure what the outcome was why the new brakes but that fixed the problem.
will this be covered under my warranty if it is the brakes? I know i have over 50% left maybe
Old Oct 11, 2004 | 03:30 PM
dv8ing's Avatar
i think that is what happened with my brothers tl, the rotors were warped! is this covered under our warranty? or will i have to cough up some dough?
Old Oct 11, 2004 | 03:40 PM
batting_cleanup's Avatar
It probably won't be covered under the warranty. Brake parts are wear items. That is a fact and one the dealer & Acura will stand behind. Have you recenly had the tires rotated or a saftey inspection done? When my wife and I moved back to Virginia we took her Toyota Avalon in for a saftey inspection, emissions, oil change and tire rotation. The grease monkey at the Goodyear place used an impact wrench on the lug nuts. Warped the hell out of the rotors and problems just like you are describing. Bad at 60, downright scary at 80 and even worse if you had to bring it down from high speeds quickly. The shop I deal with now in Ashburn knows what they are doing and luckily no problems in 5 years on any of our cars.
Old Oct 11, 2004 | 03:44 PM
fla-tls's Avatar
On the way!
...will this be covered under my warranty if it is the brakes? I know i have over 50% left maybe
Mine were - twice!
Old Oct 11, 2004 | 03:46 PM
J RIDE 81's Avatar
Team Nighthawk Director
No shakes here, take it to dealership. G'luck!
Old Oct 11, 2004 | 03:48 PM
PoochaKannInc's Avatar
Shift_faster
I agree with those that said it could be warped rotors. I think you can get them to cover it under the warranty because rotors are not "supposed" to warp, unless you have been abusing them. I know I've read on this forum that others have gotten them replaced under warranty.
Good luck.
Old Oct 11, 2004 | 03:51 PM
Diver's Avatar
if tire were unbalanced there would vibration while NOT applying brakes. i used to have it on my pontiac grand prix. going about 70+ there was some pretty good shaking going on. i brought it to have it balanced and they found out that tire was defected. had that replaced and also replaced another tire myself on the same axle. 30 minutes after i drove away - i got my ABS light on and my Traction Control System OFF light on. turned out that my rear tires were kinda baldy and due to smaller diameters (less thread) computer "thought" they were slipping and it tried to engage ABS to fix it. anywho, just traded in my Grand Prix for new TL last Saturday
and it definitely sounds like warped rotors.
Old Oct 11, 2004 | 03:56 PM
Ron A's Avatar
Administrator
Warranty:
Rotors-probably
Pads-probably not unless something cause them to go bad, like rotors.
If they cover the rotors, they will probably cover the pads, but if it is just the pads, which I can't imagine how the pads would cause this, then they would be a wear item and not covered.
Also depends on the individual dealer. I worked for a GM dealer, and one dummy didn't change his oil for 20,000 miles and the engine seized up, but they covered it and made something up for the warranty.
Old Oct 11, 2004 | 04:00 PM
Diver's Avatar
wow ! that's nice. i wish all the delaers were like that ...
Old Oct 11, 2004 | 04:04 PM
dv8ing's Avatar
I hope it is covered under warranty because its not like i abuse the car! I hope its something that can be fixed on my next appointment when oil change is due, also when my rear right window regulator is being replaced (my third one might i add)
Old Oct 11, 2004 | 06:55 PM
nick04tl's Avatar
it should be covered by warranty. at my dealership we do them under warranty 95% of the time. if your pads are really low around 2/32 then you will probably be paying for it.
Old Oct 11, 2004 | 07:55 PM
Road Rage's Avatar
Not a Blowhole
Have the runout on the hub/rotor checked. Uneven and excessive tightening of the lug nuts can cause this, as can riding the brake. None of my cars has experienced a rotor warp - am I lucky?
Some cars are prone to rotor warping - the 1990's Ford Taurus is an example. All mfrs have gone to thinner rotors, to increase fuel economy. In most cases, they have engineered the system not to have trouble when used properly. But as Ron has pointed out, rotors can warp or even crack from having water sprayed on them when they are hot, from excessive heat from mountain driving when engine braking is a better solution, from poor lug nut maintenance, from riding the brakes unconsciously, etc.
During the 1st 12 months, Acura will usually cover this - and in some cars, the known problems result in what the industry calls "hidden warranbties" - they will cover it if you make enough of the issue, but will not volunteer it (example: the "morning sickness" of GM steering racks with Teflon seals cuting into soft aluminum racks).
Old Oct 16, 2004 | 12:36 PM
anokha786's Avatar
I have the jittering / shaking action going on in my 03 TLS. Im taking it to the dealers next week, I hope it is covered under warranty. Does ne1 know forsure if warped rotors are covered under warranty.
The dealership told me an avg price of $300 to fix it all. Im def going to argue and try to get it out of warranty here.
-Ash =)
vpasla1
Sep 17, 2016 07:24 PM
prbori
Sep 27, 2015 01:37 AM
redsox68
Sep 16, 2015 06:18 PM
MikeYutkin
Sep 10, 2015 10:13 PM
Jonion
Aug 30, 2015 03:35 PM
