I feel like i'm driving a tank, 2006 5AT
Originally Posted by athlon03
car does not feel light and nimble...is it due to the fwd? turning radius stinks too
Solution to part 2 (turning radius): Yes, it sucks. Driving this car in parking lots is NOT a joy at all.
HTH..
CTS-V Import Slayer
HTH..
HTH..
Ya...there isnt much you can do about turning radius....its not good at all. Also have 5AT....try procat setup/lighter UR crank pulley and a set of Outlaw Thermoblok spacers. That will also help. BUT....as stated....it is a heavy car. If you want to get over that fact...get a supercharger. That will get you up and going. I think the fastest 1/4 mile time by a 3G TL belongs to a 5AT....believe it or not.
Registered but harmless
Received 1,150 Likes
It's a trade off...
car does not feel light and nimble... turning radius stinks too
Yes, the turning radius is wider than desireable, even for a FWD car. Our Odyssey has a better turning radius by about a foot. Fortunately, the TL does otherwise handle better than the Odyssey....
tehLEGOman
Received 1,983 Likes
The TL certainly is a tank.
I often find it hard to execute U turns and backing into parking spaces.
"car does not feel light and nimble...is it due to the fwd? turning radius stinks too"
get a good set of after market spring/ shock, that should improve the handling tremendously.
there is nothing one can do about the turning radius. front wheel drive and wide tires are the culprits. learn to get use to the car.
not vtech... VTEC!!!
uh.. tanks can turn within it's own width.
Before the TL I test drove the 300C... it's like driving a concrete bunker.
Go w/ Neuronbob's suggestion and get the A-spec suspension.
Originally Posted by AcuraVic
What were you driving before the TL?
FWIW, I have Comptech RSB on order as after driving a TL with it there is quite a noticable difference for the small $$$ it costs. Enjoy the TL .
rockyboy
08-04-2024 10:35 AM
