I drive without VSA all the time
Old May 5, 2004 | 03:14 PM
2004MT6TL's Avatar
Life is good.
So, when I get in my car to drive, I start it and proceed to turn off the VSA everytime. I just turn it on for highway or higher-speed driving. Is there a way to disable it when you start the car and turn it on when you want it.
Old May 5, 2004 | 03:17 PM
cM3go's Avatar
let us know when you go sliding into a tree on a turn :p
Old May 5, 2004 | 03:28 PM
2004MT6TL's Avatar
Life is good.
A good driver has better control of the vechile with VSA off.
If you want to, you can put the car into a spin tho, pretty fun.
Old May 5, 2004 | 04:47 PM
jjay's Avatar
this is exactly how i drive turn on the car and turn vsa off
Old May 5, 2004 | 04:53 PM
2004MT6TL's Avatar
Life is good.
Nice, Team VSA-off
Old May 5, 2004 | 05:13 PM
SpringsAcura's Avatar
Before you go turning it off, it is good to understand what VSA does for you and how it does it. The VSA (vehicle stability assist) is a two part safety system. The first system is traction control, which works at speeds below 18 mph. in marginal traction condition such as snow, ice, or sand, the VSA will pull torque away from only the wheel that has lost traction and transfer it to the other wheel. It also uses the ABS to stop any wheel from spinning. if both wheels have poor traction, it will "bounce" the torque between the wheels to get you going. It is kind of the reverse of ABS.
At higher speeds, the the VSA acta as a "yaw" control. It corrects oversteer and understeer (skidding). It is designed to keep you on your intended turn path whether due to loss of traction from conditions or emergency maneuvering. In an understeer, the Vsa will cut torque and apply ABS to the interior front wheel of the turn ie - left turn understeer, then left front tire. In oversteer, it cuts torque and applies ABS on interior rear wheel only. It only comes on when this condition is detected. Again, if you are doing aggressive cornering, the VSA doesn't cut torque from both drive wheels, only the one that has lost traction as it applies the ABS to one wheel only.
BTW -- the new 2005 RL with SH-AWD will combine the ABS, VSA and SH-AWD so that when cornering, the torque is transferred to the outside wheels of the turn. VSA works on interior wheels of turns, so this big demon should a screamer and as sticky asmy toddler's face after an ice cream cone!
Old May 5, 2004 | 05:16 PM
jjay's Avatar
Originally Posted by 2004MT6TL
Nice, Team VSA-off
i should have known 2004 our cars are alike anyone with silver sixspd turns the vsa off!!! i hate feeling the car start to corect itself cause it thinks im goin to fast after eighteen yrs of driving without vsa why should i start now check my car out at
http//:www.cardomain.com/memberpage/550993
Old May 5, 2004 | 05:23 PM
jjay's Avatar
springs i sort of like the out of control feeling, i guess thats from my 78 280z days, and not that the tl is a race car but i would almost bet my car that i could win a race with the exact car, me with the vsa off and say me or just about whoever with the vsa on in a sreet race or a actual timed course race....now in rain or snow offcourse vsa on other than that vsaoff
mada51589
Jan 9, 2025 04:40 PM
Feb 25, 2020 09:57 AM
Skirmich
Sep 15, 2015 06:41 PM
BC01191980
Sep 7, 2015 08:14 PM
Stu2414
4G TL Problems & Fixes
Aug 30, 2015 07:30 PM
