I did a compression test.
Old Mar 27, 2010 | 10:46 PM
NCTL05's Avatar
Middle Finger anyone?
Hello everyone. I did a compression test on my ride and she passed with flying colors. I did exactly 4 cranks on each cylinder. I was so happy with the results I thought I would share. Also my car has 78k miles and I was so pleased to see how well the engine is holding up for this kind of mileage. The service manual says there should be a minimum of 135psi, but it doesn't say what it should be at it's best sooo I am assuming these are good numbers.
I got... Back
(240)(235)(240)
(244)(235)(237)
Front
Not more than 2% difference between the lowest and highest number. I guess I would be good to go if I ever go for the supercharger.
Old Mar 27, 2010 | 10:51 PM
princelybug's Avatar
LIST/RAMEN/WING MAHSTA 짱
I wonder what the numbers should be at?
Old Mar 27, 2010 | 11:14 PM
NCTL05's Avatar
It's a high compression motor sooo I would think it should be greater than 200psi so your guess is as good as mine.
Old Mar 27, 2010 | 11:25 PM
I hear you. 135 seems low?
Old Mar 28, 2010 | 01:25 AM
I hate cars's Avatar
Cams contribute just as much or more to compression results as mechanical compression ratio. If the engine uses fairly aggressive cams, even with a high compression ratio, the psi on a compression test can still be low.
Small cam low compression engines can show high psi numbers on a compression test.
All you're looking for is consistency between all 6 cylinders. Ideally the test should be performed with no spark plugs and the throttle wide open but again, all we're looking for is consistency.
The 2% number is great, that's what I would focus on.
Old Mar 28, 2010 | 04:29 AM
01tl4tl's Avatar
the throttle being held wide open is a major influence on the numbers reality
you can go more than 4 revolutions to watch for initial, any increase and final compression numbers- 6-7 revs will provide a lot of information
as said- the 2% differance is great- are those canadian numbers? the min allowed is the min the car will still run at...should be a norm range available somewhere for repair techs to work from
Would be interesting to seafoam it and see if it changes compression/reduces it from carbon buildup on the pistons
My honda 2 wheeler owner book talks about that, and requires top end cleaning/decarbonizing on a regular basis to prevent too much compression in an interferance engine and possible valve to piston contact from raised piston height!!
Old Mar 28, 2010 | 11:32 AM
NCTL05's Avatar
Those numbers are psi. And I did have the gas pedal and clutch depressed during cranking. And the spark plugs were out of all cylinders.
A little of topic, but I have the E3 diamond fire sparkplugs.Since I had them out I noticed that there was a little carbon buildup on the plugs. For awhile I noticed extra carbon on my exhaust tips and I think the plugs might be the culprits. So after a little while I am going to get the NGK iridiums again.
Old Mar 28, 2010 | 11:35 AM
e30cabrio's Avatar
LFG RANGERS!!!!!!!!!!!
I suggest removing the E3s & going OEM.
IMHO those plugs are snake oil.
Old Mar 28, 2010 | 11:44 AM
01tl4tl's Avatar
the TL -with its already hi energy ignition with coil on plug technology..does not benefit from trick plugs like other cars may
the NGK Iridium is the right part for the job!!
Use a tiny amount of plug thread anti sieze on the middle 2-3 threads, dont want it getting inside the cylinders-- but do want some to keep plugs from sticking
Old Mar 28, 2010 | 01:00 PM
e30cabrio's Avatar
I tried them in my 94 Land Cruiser, there was no change of any kind. I took them up on their $ back offer, took almost 3 months to get the $ back.
1fatcrxnem1
22
Jun 1, 2018 01:23 AM
mossman77
1/2G MDX (2001-2013)
18
Sep 16, 2015 12:21 PM
Sep 13, 2015 01:59 PM
gavriil
Sep 16, 2007 08:15 PM
Jun 5, 2003 05:17 PM
