How does it work?
Old Apr 11, 2005 | 07:06 PM
crazymjb's Avatar
How does it work?
When the rear view mirror senses headlights does it angle it self down, or does it tiint the glass(with liquid crystal). Are there any other electronic devices in the mirror?
Old Apr 11, 2005 | 07:29 PM
rets's Avatar
Moderator Alumnus
For the interior rear view mirror, if you press the button to turn on the feature, the mirror will auto-dim based on light of day/night.
Old Apr 11, 2005 | 08:22 PM
bluenoise's Avatar
2004 SSM/EB/5AT/Navi/RSB
The glass is "photochromic." I don't know if it uses liquid crystal technology to do this, but it definitely dims. It takes a few seconds to do this. If I'm parked in my dark garage with the door open, the bright sunlight from outside dims my mirror. I can turn off the switch on the mirror and watch it brighten. Hit the switch again and the image dims down to a slightly purplish-blue color.
Old Apr 11, 2005 | 09:19 PM
ayethetiense's Avatar
.:KCCO:.
that seems cool to have. too bad i have a wide angle view mirror and it totally covers it all up.
anyone know if this feature is "on" if it uses power? im sure it cant be using much if any at all, but might as well have it off if i dont have any use for it right?
Old Apr 11, 2005 | 09:30 PM
bluenoise's Avatar
It probably only draws a couple of milliamps. I doubt one could detect the power usage in the grand scheme things (ie. improved fuel economy, etc.).
Old Apr 11, 2005 | 10:21 PM
crazymjb's Avatar
But letting it sit... So, it dims when in direct light? Or dims at night when everything else is dark?
Old Apr 12, 2005 | 01:50 AM
bluenoise's Avatar
It dims any time light is hitting the sensor, which is visible in the little hole in the bezel under the mirror. It doesn't matter if it's day or night or if the headlights are on. The only thing that affects it is whether or not it is turned on (green LED is lit to show it's on).
Old Apr 12, 2005 | 09:12 AM
JohnDoe2's Avatar
I'm not sure about that. On a bright sunny day, we do not want ANY dimming. I would expect when the ambient light is low, it dims. Just the opposite of what your pupils do.
When dark, your pupils allow more light and the mirror darkens....
Old Apr 12, 2005 | 10:19 AM
Champcar1's Avatar
Is it tied to the headlights being on in any way? In other words even if the mirror is turned on, will it not dim unless the headlights are on?
Old Apr 12, 2005 | 10:30 AM
Ron A's Avatar
Administrator
Not tied to headlights. Mirror works independently and on its own.
Old Apr 12, 2005 | 10:44 AM
Lore's Avatar
CEO, Team Anthracite
There are two sensors. One in the back of the mirror (facing the front of the car) which detects ambient light, and the second which is on the front of the mirror (facing the rear of the car) which detects headlights and other bright light sources.
If the ambient sensor detects that it's dark, the light sensor will be "dimmer switch" so to speak. Depending on how bright things are, it will dim the mirror.
To easily test this, cover the ambient sensor with your finger in broad daylight. You will see the mirror dim instantly because now the mirror thinks 1) it's night outside and 2) there is a lot of bright light behind you.
Old Apr 12, 2005 | 10:51 AM
scrb09's Avatar
MAKES Sense!
Old Apr 12, 2005 | 11:43 AM
hopsdevil's Avatar
Would it hurt to leave it "on" all the time? Can it "burn" out if left on for say years?
Old Apr 12, 2005 | 02:05 PM
bluenoise's Avatar
Exactly. This is why it dims when I open my garage door in the morning. The garage is relatively dark but the sunlight from outside pours in and hits the sensor under the glass and dims it.
I don't think it will wear out if used all the time.
Old Apr 12, 2005 | 05:03 PM
1995hoo's Avatar
Keep Right Except to Pass
"Interior"? What other rear view mirror is there?
Old Apr 12, 2005 | 07:31 PM
bluenoise's Avatar
Some refer to the side mirrors as "rear-view," too.
Old Apr 13, 2005 | 12:20 AM
ramilford's Avatar
Smile
That is correct. I have tested it too.
Old Apr 13, 2005 | 06:14 AM
mickey3c's Avatar
Mine still worked after 83,000 miles no problem. But I had it off most of the time. The thing was too sensitive and would dim whenever there was someone behind you. I like to get a better indication of when someone is behind me when I am driving on the highway for passing etc. I felt that it dimming all the time made it more difficult to judge traffic etc. Or tell if it was a state trooper behind you in the dark...
Old Apr 13, 2005 | 03:37 PM
jdone's Avatar
My Lexus has the auto-dimming feature on all three mirrors. This makes a big difference and is the kind of stuff Acura has to start doing to compete.
mada51589
Jan 9, 2025 04:40 PM
spidermankb
Mar 5, 2019 11:34 AM
acurajj
Sep 19, 2015 03:47 PM
Luis J. Rodriguez
Sep 12, 2015 10:00 PM
ahsm
Sep 9, 2015 08:35 AM
