How do you pull off the middle Acura emblem?
Old Jan 20, 2012 | 09:47 PM
TLmalloy's Avatar
I want to know how to pull off the middle acura emblem, and paint it black, but i dont know how to do it right. I figured at least one person on here would know hot to. Will you please let me know? Aslo if im going to paint it black what kind of paint would i use so the black paint doesn't flake off?
Old Jan 20, 2012 | 09:50 PM
guitarplayer16's Avatar
Take out the grill piece (there's like 6 screws holding the grill piece in from behind the bumper).
Then once the grill piece comes out, so will the emblem and you can unscrew the emblem from the back of the grill piece.
Old Jan 20, 2012 | 09:54 PM
powerflow's Avatar
Wiggy Wiggy Wiggy
Front or back?
IMO do both otherwise it doesn't flow.
I would take it to a shop that uses high end paint, and can prep it correctly.
If you use spray paint, expect the front to chip over time. A good spray paint is Krylon Fusion or the Plasti-Dip.
If you search, there is probably more in depth removal instructions.
Old Jan 20, 2012 | 09:58 PM
TLmalloy's Avatar
Yeah i want to do both, but how do you take off the middle back emblem? Ive already took off the ACURA and the TL with fishing line and a heat gun but the middle one looks a little more difficult lol.
Old Jan 20, 2012 | 10:05 PM
powerflow's Avatar
Wiggy Wiggy Wiggy
The rear has double sided tape, and 2 pins.
The two plastic pins connect to plastic retainers on the trunk. The trunk has two holes in the outer skin for the rear emblem pin retainers.
It removes by prying it out with a little force and finesse. To make it easy, use a heat gun to loosen the double sided tape. Or, fishing line can be used to cut through the tape. New tape should be re-applied, especially if the old tape gets torn in any way.
Plastic pry tools work great to ensure the outer panel does not get scratched or gouged.
Old Jan 20, 2012 | 10:19 PM
TLmalloy's Avatar
Do you think it would be better to just tape off them back emblem and paint it, or should i remove it? then paint it. Have you ever heard of platidip paint?
TLmalloy's Avatar
Old Jan 20, 2012 | 10:20 PM
TLmalloy's Avatar
Should i do it like that^^^ or pull it off? When you pull it off does it come off of that fat part on the back of the crome emblem or does that whole fat part come out?
Old Jan 20, 2012 | 10:41 PM
rptls08's Avatar
WDP Type-S sitting on air
i tried taping the back emblem off and it didnt work too well. i ended up taking it off and plasti-dipping it. worked much better and looks cleaner
sauceja's Avatar
Desert Life Sucks!!
I just took mine off tonight. will be plasti-dipping my grille tomorrow.
Once the bumper is off there are like 7-9 screws and the grille assembly comes to pieces then there are 2 more screws and the A and border come out.
It is pretty straight forward once bumper is off.
End result:
Old Jan 20, 2012 | 10:53 PM
TLmalloy's Avatar
Im thinking i dont even wanna go through the time of taking off the emblems because thats the only thing im painting. Should i just plastidip it since it peels off easy?
Old Jan 20, 2012 | 11:14 PM
sauceja's Avatar
Desert Life Sucks!!
I decided to pull everything apart to clean each piece and paint separately. To each his own.
It seriously took me 20 minutes while working at 40% speed to take off the bumper. I don't want to have to peel anything or redo this later.
Either way good luck.
Old Jan 20, 2012 | 11:21 PM
TLmalloy's Avatar
Good idea! Thank you!
Old Jan 21, 2012 | 12:48 AM
hotgrease's Avatar
2004 AM TL
The back is so easy to take off I'm not sure why you wouldn't. Just use fishing line/dental floss and slide from top down and bottom up (use a heat gun to soften it first). There are two clips halfway down the emblem, one on the left and one on the right. You'll feel the floss stop when you hit them. Then just gently pry it off. I wouldn't use the method shown in the Youtube video.
Old Jan 21, 2012 | 03:16 PM
sauceja's Avatar
Desert Life Sucks!!
I plan on painting everything BUT the A though just FYI.
I want the chrome trim around grille and the A left alone everything else will be blacked out.
saberlove
Mar 11, 2021 09:29 AM
HOWELLiNC
3G TL Photograph Gallery
24
Oct 8, 2015 03:15 PM
Marmbo
4G TL Problems & Fixes
Sep 21, 2015 09:39 AM
sputik
Sep 7, 2015 01:40 PM
