How do I remove reverse light covers?
I must really suck at searching because I couldn't find what I was looking for, hopefully someone can help me.
I want to remove my reverse light covers so I can black them out with tint. Can someone please explain how to do this. It looks like it would just pop out from the inside of the truck but I want to know the right way because I'm afraid i'll break something. I tried pulling it out at all different angels and it won't budge. Maybe the whole exterior rear assembly comes out? I'd appreciate it if someone will shed some light on this topic.
Thanks!
Thanks!
I added the thread with the scans to the 3G Garage. It was there but difficult to find with a search, so this will make it easier.
G-052: DIY: Replacing License Plate and backup light Bulbs
https://acurazine.com/forums/showthread.php?t=105472
https://acurazine.com/forums/showthread.php?t=125207
https://acurazine.com/forums/showthread.php?t=124574 Backup light replacement
That only tells you how to change the bulb, and here's the thread for removing the license plate frame so you can get at the backup light. I don't think it tells you how to remove the cover of the light because it is probably made all in one piece, but you will know more when you get it out and then you can let us know how it went.
E-034: DIY:Removing aluminum strip above rear license plate & trunk liner?
https://acurazine.com/forums/showthread.php?t=84489
cycdaniel
12-17-2019 10:58 AM
Soul_Deamon
4G TL Problems & Fixes
11-02-2015 04:32 PM
wusty23jd
09-24-2015 11:41 AM
