How do I remove frisbee scuff mark?
I was playing frisbee fetch with our lab. A gust of wind caught the the fribee and it hit the right front fender, and put a nice 2-3" long scuff in the clear coat. No major scratches, just a scuff. So far the car has one door scrape in 2 years and just this scuff from my own poor decision. The poor dog was mortified when I issued my string of expletives, thought I was yelling at him. Gave him a treat... to make up for it.
Any help is appreciated
Go with the ScratchX ... leave the compound out of the equasion for now. Rule of thumb is always to go least agressive first and use it longer . Going more aggressive just means you may create issues you will have to correct.
Once you use ScratchX apply some wax over the area.
If you need to, use the ScratchX on a terry towel it has more bite, then follow with the ScratchX on a very soft cloth. Then wax.
That sounds like a plan... I hadn't thought about the scratchX, I was assuming some form of rubbing compound. Do no harm is a good idea
Thanks all
Try wax first; waxes generally have sufficient abrasiveness to remove scuff marks. A Toyota Forerunner struck our Odyssey's rear bumper this past Saturday; Meguairs liquid wax removed slight scuff marks completely. The scuff mark was transfer from the Forerunner's polyurethane bumper cover. Hopefully your scuff mark is from the frisbee material (as has happened to me before as well!) and not a scratch to the clear coat.
If wax isn't abrasive enough, go to Scratch X or polishing compound (which is different from rubbing compound).
Then rubbing compound as last resort...
CL-S progression 01
Jan 26, 2016 04:15 PM
dainmezron
Oct 16, 2015 06:56 PM
detailersdomain
Wash & Wax
Oct 9, 2015 10:13 PM
