How do i get rid of this ....
Old 12-23-2008 | 04:36 PM
ikm19's Avatar
i need to get rid of this line thats all round...
any ideas ? i mean it look too bright.. i don't know why...
Old 12-23-2008 | 04:46 PM
CSWBiggs's Avatar
poor grammer overload...lol
u may need to use this....
Matco SE712k
-Jason
Old 12-23-2008 | 04:50 PM
csmeance's Avatar
you might be able to peel it off if its a sticker, heat up with hair-drier and try peeling.
Old 12-23-2008 | 04:58 PM
ikm19's Avatar
Thanks CSWbiggs ( Poor Spelling mistake.. its grammar not grammer ) ...
I was thinking with heat gun.. but it might mess up the paint...
Old 12-23-2008 | 05:26 PM
Nasty188's Avatar
Have A Nice Day!!!
I think you can peel it off and then finish wiping it with "Goo Gone" wich you can purchase at your local "auto Zone or R&S Strauss"
Old 12-23-2008 | 06:22 PM
wasupdog's Avatar
My Garage not
watch out when u try peeling it. if u bring a fingernail or any object within 500 feet of the tl's paint it'll scratch. i swear the paint will scratch if u blow on it haha.
Old 12-23-2008 | 06:32 PM
Cap'n Preshoot's Avatar
At least the TL's sheet metal is a lot heavier than that on my Dodge Ram pickup. I swear if you stare hard enough at the truck you'll leave two dents in it.
Old 12-23-2008 | 07:02 PM
ikm19's Avatar
I did try to peel it off, but there is some kind of coating over it.
Old 12-23-2008 | 07:11 PM
Turbonut's Avatar
Is it paint or tape?
Old 12-23-2008 | 07:30 PM
I hate cars's Avatar
So true. The bodyshop that just did the repaint on my car said the paint is incredibly thin on these cars. My black TL looked like it was gray in the front from all of the chips.
Old 12-23-2008 | 07:39 PM
Turbonut's Avatar
Black cars have the thinest application of paint applied. White the most. At least at GM plants this is true, so I assume it holds true throughout the industry.
Old 12-23-2008 | 08:10 PM
wall e's Avatar
TL=True Love
i dont mean to sound rude, but if u didnt want that on the car, why did u buy that car then?
Old 12-23-2008 | 08:13 PM
That's really good to know! Now it makes sense why my TL is so much worse than a friend's TL with about the same mileage.
Old 12-23-2008 | 08:19 PM
Nasty188's Avatar
Have A Nice Day!!!
I was gonna say maybe it's second hand but then i noticed the signature "08 type-s" or maybe he got a better offer on it!
Old 12-23-2008 | 08:37 PM
ikm19's Avatar
^^ i don't know I got a better deal but I did paid $36500 for it.. I don't prefer anything used or second hand...
Wall -e <--- I got mine f**king car for same reason that you got it for....
Old 12-23-2008 | 08:38 PM
ikm19's Avatar
Thats what i was worried...
Old 12-23-2008 | 08:46 PM
ikm19's Avatar
I hope its tape.. i did try to remove it from one side, but it has some kind of factory coating.. tomorrow morning i will take it to body shop and see what the guy has to say...
I was looking some pictures in picture threads and not a single car has that ugly sticker....
Old 12-23-2008 | 08:56 PM
ikm19's Avatar
more pics
Old 12-23-2008 | 09:35 PM
Trew's Avatar
It would look better if you added door mouldings
Old 12-23-2008 | 10:22 PM
powerflow's Avatar
Wiggy Wiggy Wiggy
It could be paint or a adhesive decal, the logo is definitely a decal. The eraser wheels (pic'd above) work great, and fast too on the decal pin strips.
Paint is going to be tricky to remove. A strong solvent and elbow grease, or wet sanding will be needed.
Not only is the base thin, but the clear is thin too. Honda paint is really not all that great from the factory.
Old 12-23-2008 | 10:50 PM
ikm19's Avatar
^^^ thanks powerflow thats like a straight answer and thats what i was looking for.. thank you again...
Old 12-23-2008 | 11:10 PM
inyong1988's Avatar
seems like a tape to me. it's easy, leave your car outside on sunny day for few hours and peel it off slowly and carefully, if you living in an area with cold weather, use heat gun or blow dryer and heat up the surface and slowly peel it off. After you get it off, use a goo gone to clean up the surface when it was taped. Wash your car and use meguiar's 3 steps wax it up you're good to go.
P.S. If it's painted, there's no way you can take them off unless you professionally paint top of that but I doubt you want to do that.
Good luck.
Old 12-23-2008 | 11:13 PM
Will Y.'s Avatar
Registered but harmless
If the pinstripe tape was properly laid, there is probably a clear coat on top of the tape's edges-- that may be the "coating" you're feeling. Back in the day, I put a dab of clear enamel over the front and rear edges of the pinstripe tape to keep it from lifting.
If you haven't dealt with it before, have a body shop look at it and get an estimate for removal.
Old 12-23-2008 | 11:43 PM
Aman's Avatar
Your Friendly Canadian
Am I the only one who actually kinda likes the pinstripe?
Old 12-23-2008 | 11:49 PM
tmnhs81's Avatar
Awesome.
Old 12-24-2008 | 06:51 AM
powerflow's Avatar
Wiggy Wiggy Wiggy
Good luck.
Not quite. I've removed painted strips with both methods I mentioned above. One car sat in the sun for a few days after getting striped the wrong color. I used a strong solvent and elbow grease. Other cars I have used wet sanding, very, very carefully and finessed the area out. The trick is to knock down the clear just a tiny bit, so you don't have a flat profile down the side if the car. Wet sanding is not ideal but it does get the job done. Honda clear is already thin so it does takes finesse work and special small blocks so you hit just the pin strip.
Old 12-31-2008 | 06:31 PM
win63dow's Avatar
YES
Old 12-31-2008 | 09:18 PM
ABP_04TL's Avatar
6-SPEED LOVER
i would of removed that the same day after receivin the car....
i agree with Nasty188 heat & goo gone is ur friend
Old 12-31-2008 | 11:14 PM
vinnier6's Avatar
i remember back in 89, i bought a honda crx si, it was bright yellow with a black pinstripe on it....before i drove it off the lot i stood out front of the dealership and peeled it off and threw it away....that pinstripe you have is not a painted pinstripe, that is your run of the mill add dealer add on and can be peeled right off...since its winter, use a hair dryer and heat it up in small spots and start peeling it off slowly...it will come off....
Old 01-01-2009 | 02:10 AM
Elegant TYPE S's Avatar
Being an Acha Bacha in
Its most likely stickers, because you got that A logo there too, no one is going to paint that, too much work. I would just use a hairdryer and try peeling. Goo Gone afterwards to clean up the residue and then throw some cleaner wax to finish it off. Done deal.
Old 01-02-2009 | 09:15 AM
alexSU's Avatar
Under construction
I had the exact same thing and just peeled it off. Washed the car and waxed right after and it look awesome! No biggie, like ppl said above...just peel it
drillzzz
07-28-2019 06:30 PM
jspangan
ILX
19
08-30-2016 05:37 PM
c1souk
09-28-2015 11:20 AM
carz0159
09-20-2015 06:11 PM
BMA1078
09-19-2015 11:31 AM
Quick Reply: How do i get rid of this ....
